Aple PC?
  • ivtec
    • Dec 2008
    • 1967
    Re: Aple PC?
    Originally posted by Time2Retire
    I retired from offering help on BCN, but I better help you since you followed something I recommended!
    Those error messages are for your wireless. The Broadcom B43xx family of Linux drivers need firmware added to work. It can easily be added via the package manager. (but you need a wired internet connection)
    Your real problem is the blank screen. This sounds like a video driver problem. Try to access a terminal screen by using a key combination of Ctrl+Alt+F1 through Ctl+Alt+F10. Usually the F2 or F7 combination is your "Desktop", which currently is blank.
    If you can get a terminal prompt, you can login. Then we can look to see what went wrong.
    Thanks for your kindness,i press ctr+alt+f1 or ctl+alt+f10 and it does't go anywhere when do i press these keys before this message that shows on black screen or when is booting when it's booting?
    • Time2Retire
      • Aug 2012
      • 256
      Re: Aple PC?
      After it is finished booting, and it seems to stall. Also, try the key combinations between F1 and F10.
      Did you install it to the hard drive, or are you booting from the CD or USB drive?
      • ivtec
        • Dec 2008
        • 1967
        Re: Aple PC?
        thanks TimeRetire, i apreciate ok pressed those keys but it wont move ,
        when booting i have the choice of typing directories,is there when command that will take me to terminal or other place? thanks
        • ivtec
          • Dec 2008
          • 1967
          Re: Aple PC?
          I installed it in the hdd erased the mac stuff and used the full hdd,
          at the screen presented to me with that request of those drivers it just don't obay tothe keyboard
          • Time2Retire
            • Aug 2012
            • 256
            Re: Aple PC?
            Do you get a screen similar to this:
            If so, what type of options does it offer? You mentioned about getting a keyboard. Maybe that is part of the problem, in that the keyboard you are using isn't working.
            If you have never used Linux before, maybe this isn't the best way to learn it. You can't learn much if it doesn't boot. It is also hard to troubleshoot if you don't know what to expect.
            • ivtec
              • Dec 2008
              • 1967
              Re: Aple PC?
              Know ,also i put in the cd and i can't get out,it seems when is booting it sais loadindin kernel at same time sais boot on a black screen i can type command but none that i know of is valid.I try to reenstall with the cd iso that is inside and it sais fail for now maybe i have to open it up to eject the dvd,
              what a piece of crap computer aple is a piece of crapp just for that if you do not use aple software you're dead
              • ivtec
                • Dec 2008
                • 1967
                Re: Aple PC?
                Sorry for the mispell i meant No instead (know,=i do not get that screen, what i get is after I boot it says 'first stage ubuntu bootstrap it asks me if
                i want toot from GNU/LINUX press l if i want CD press C
                when it sais well com to yboot 1.3.16 than stays froze at that message where it requests the fs b43-phy0 Error
                • ivtec
                  • Dec 2008
                  • 1967
                  Re: Aple PC?
                  Hi guys new update on my Mac ppc g5 inatall need some help, i downloaded the Lubuntu 64bt 12.10 for mac ppc and it installed as easy as Ubuntu but it improved but now i get stuck at terminal, i can login by pressing ctr alt f1 combination ask name and password i can get in the terminal i could do sudo apt-get upgrade and it updated all software updates but still can't get to desktop,
                  i think this is a graffic card problem maybe! lack of drivers.now i'm better with Lubuntu cause have control, now what comands should i do to bring desktop back or get the right i think this is Nvia drivers not sure!thanks in advance.
                  • Time2Retire
                    • Aug 2012
                    • 256
                    Re: Aple PC?
                    OK, I have two commands for you to run. The first one will install all of the firmware that is freely available for the Broadcom wireless drivers. Hopefully it has the one your wireless needs, but it won't be much use until you get the GUI running.
                    Code:
                    sudo apt-get install firmware-b43*
                    OK, now to try and troubleshoot the graphics. There is a log kept in the /var/log/ directory for the graphics. It can get large and hard to read, so this command will only show the warnings and errors.
                    Code:
                    grep /var/log/Xorg.0.log -e EE -e WW
                    If there are a lot of warnings and errors, it will scroll by without you being able to read it. Then you need to use the "less" option, and use the Enter key to advance a line, the "q" key to quit.
                    Code:
                    less /var/log/Xorg.0.log | grep -e EE -e WW
                    • Time2Retire
                      • Aug 2012
                      • 256
                      Re: Aple PC?
                      One other thing that I was wondering. Did the graphics work OK when you booted off of the live CD (Desktop showing)? If so, we may be able to copy the configuration that the LiveCD makes, and use it for the installed Ubuntu.
                      • ivtec
                        • Dec 2008
                        • 1967
                        Re: Aple PC?
                        Thanks; first thing i try to sudo apt-get install firmwareb43*
                        I get this message
                        reading packages lists...done
                        Buildind Dependeny tree
                        reading state information...done
                        Note, sellecting 'firmware-b43 Legacy-installer' for regex 'firmwareb43
                        Some packages coul not be installed. This may mean you have
                        requested an impossible situation or if you are using the unstable
                        distribution that some packages have not been created
                        or moved out of incoming.
                        the following information may help to solve the situation:
                        The following packages have unet dependencies:
                        firmware-b43-installer : conflicts: firmware-b43-1pph-installer but 1.015-14 is to be installed firmware-b43-installer : conflicts: firmware-b43-1pph-installer but 1.015-14 is to be
                        E:Unable to correct problems, you have held broken packages
                        now is the commands you gave me bellow are correct! it sais invalid
                        grep/var/log/xorg.0.log -e EE -e WW
                        less /var/log/xorg.0.log grep -e EE -e WW
                        • Time2Retire
                          • Aug 2012
                          • 256
                          Re: Aple PC?
                          Forget about the WiFi firmware for now. That can be done later.
                          You typed them in wrong. The first one should have a space between the command (grep) and the path to the file (/var/log/Xorg.0.log). On the second one you omitted the vertical bar (|), and added a space instead. Make sure you type them in exactly as I showed, including capitol letters where I had them.
                          • ivtec
                            • Dec 2008
                            • 1967
                            Re: Aple PC?
                            When i booted of the cd i have the lubuntu light blue logo for a sec then it goes blank with black screen with a tiny graffic 2 inches square with the mouth pointer then i have to press Ctrl +ALt+F1 to get to the log in black terminal
                            also i tried those commands
                            This one open and says not exist
                            this one opens also with all the info but nothing mentionig (Less)
                            or no graffics info just ubuntu info
                            i cannot type all the stuff if i had a nice camara to take a pic but my camara takes a pic but can't see the tex cause is blurr
                            the first
                            • ivtec
                              • Dec 2008
                              • 1967
                              Re: Aple PC?
                              Hi guys i don't know if i posted the Mac PPC that i have but here goes the Link
                              http://www.ebay.com/itm/Apple-iMac-2...-/261259858957
                              • ivtec
                                • Dec 2008
                                • 1967
                                Re: Aple PC?
                                HI GUYS, i made a video of booting up with ubuntu 12.10 installed i can't pass the terminal.
                                https://www.youtube.com/watch?v=BziP...jvOmHwM0WycHiw
                                • ivtec
                                  • Dec 2008
                                  • 1967
                                  Re: Aple PC?
                                  Hi guys: sorry to bring this up again,but i checked the ubuntu website and checked requirement to install ubuntu and it says 1GB MEMORY RAM,so i thought this might be my problem since i only have 512bt memo there is a slot to install one set of memory.
                                  Any advice on that thanks in advance
                                    ACER Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro Veriton 530 Specification for Upgrade or Repair
                                    This specification for the ACER Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro boardview and Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                    09-12-2024, 03:36 PM
                                    ACER Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP Veriton 630 Specification for Upgrade or Repair
                                    This specification for the ACER Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP boardview and Veriton Veriton 6800 P4 Int630 512MB 80GB AZB XP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                    ACER Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP Veriton 820 Specification for Upgrade or Repair
                                    This specification for the ACER Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP boardview and Veriton Veriton 7800 P4 3000 512MB 80GB AZB XP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                    ACER Veriton Veriton 7800 P4 3000 512MB 80GB US Veriton 830 Specification for Upgrade or Repair
                                    This specification for the ACER Veriton Veriton 7800 P4 3000 512MB 80GB US can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 7800 P4 3000 512MB 80GB US boardview and Veriton Veriton 7800 P4 3000 512MB 80GB US schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                  • madyoyo
                                    Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
                                    by madyoyo
                                    Hi
                                    I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
                                    Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
                                    12-01-2023, 09:28 AM
