help on linux disro and wireless connection
Re: help on linux disro and wireless connection
i realy like this wheezy but if i can't install the ipi2200 files and also can't install flash player,also can figuere this out when i try to use the terminal it asks for my password and i type it and it gives me this,don't know whatelse to do.but go back to try to reestall the winxp from my 2 recovery disksLast edited by Time2Retire; 06-01-2013, 01:11 PM.Comment
I actually already gave you step-by-step instructions. Just follow them exactly, and your wireless should work.
now i loaded another Distro Xunbuntu it run great on this machine and actualy like it better the the demian 7 wheezy,but it has the same problem wire cable works great but the wireless nothing,I thing it has to do with the ipi2200 drivers.thanks in advanceComment
Xubuntu is a lightweight version of Ubuntu. Ubuntu should have built-in support for your wireless, so then Xubuntu should to. You shouldn't have to install anything extra.
Post the output of these commands (you can copy/paste them):
Code:dmesg | grep firmware
Code:lsmod
Code:iwconfig
Code:lsmod
Code:iwconfig
dmesg I grep firmware , remember the slash i did no understand so i could not delivered the info, so today i was just trying comands and got it right, here goes the info.
dmesg [options]
Options:
-C, --clear clear the kernel ring buffer
-c, --read-clear read and clear all messages
-D, --console-off disable printing messages to console
-d, --show-delta show time delta between printed messages
-E, --console-on enable printing messages to console
-f, --facility restrict output to defined facilities
-h, --help display this help and exit
-k, --kernel display kernel messages
-l, --level restrict output to defined levels
-n, --console-level set level of messages printed to console
-r, --raw print the raw message buffer
-s, --buffer-size buffer size to query the kernel ring buffer
-T, --ctime show human readable timestamp (could be
inaccurate if you have used SUSPEND/RESUME)
-t, --notime don't print messages timestamp
-u, --userspace display userspace messages
-V, --version output version information and exit
-x, --decode decode facility and level to readable string
Supported log facilities:
kern - kernel messages
user - random user-level messages
mail - mail system
daemon - system daemons
auth - security/authorization messages
syslog - messages generated internally by syslogd
lpr - line printer subsystem
news - network news subsystem
Supported log levels (priorities):
emerg - system is unusable
alert - action must be taken immediately
crit - critical conditions
err - error conditions
warn - warning conditions
notice - normal but significant condition
info - informational
debug - debug-level messages
frank@VGN-A195EP-PT:~$ lsmod
Module Size Used by
tifm_sd 17566 0
joydev 17393 0
snd_intel8x0 33455 3
snd_ac97_codec 110213 1 snd_intel8x0
ac97_bus 12642 1 snd_ac97_codec
snd_pcm 80916 2 snd_intel8x0,snd_ac97_codec
snd_seq_midi 13132 0
snd_rawmidi 25424 1 snd_seq_midi
snd_seq_midi_event 14475 1 snd_seq_midi
pcmcia 39826 0
radeon 733914 2
snd_seq 51592 2 snd_seq_midi,snd_seq_midi_event
snd_timer 28931 2 snd_pcm,snd_seq
snd_seq_device 14172 3 snd_seq_midi,snd_rawmidi,snd_seq
psmouse 96718 0
tifm_7xx1 12937 0
snd 62218 13 snd_intel8x0,snd_ac97_codec,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
tifm_core 15040 2 tifm_sd,tifm_7xx1
ipw2200 146210 0
libipw 46732 1 ipw2200
cfg80211 178877 2 ipw2200,libipw
ttm 65344 1 radeon
soundcore 14635 1 snd
serio_raw 13027 0
yenta_socket 27428 0
pcmcia_rsrc 18367 1 yenta_socket
drm_kms_helper 45466 1 radeon
snd_page_alloc 14115 2 snd_intel8x0,snd_pcm
lib80211 14040 2 ipw2200,libipw
pcmcia_core 21511 3 pcmcia,yenta_socket,pcmcia_rsrc
drm 197641 4 radeon,ttm,drm_kms_helper
sony_laptop 39681 0
parport_pc 32114 0
mac_hid 13077 0
rfcomm 38139 4
bnep 17830 2
bluetooth 158479 10 rfcomm,bnep
ppdev 12849 0
i2c_algo_bit 13199 1 radeon
asus_laptop 23693 0
sparse_keymap 13658 1 asus_laptop
input_polldev 13648 1 asus_laptop
shpchp 32265 0
lp 17455 0
parport 40930 3 parport_pc,ppdev,lp
usbhid 41937 0
hid 77428 1 usbhid
firewire_ohci 40180 0
firewire_core 56940 1 firewire_ohci
e100 36289 0
crc_itu_t 12627 1 firewire_core
frank@VGN-A195EP-PT:~$ iwconfig
lo no wireless extensions.
eth1 IEEE 802.11bg ESSIDff/any
Mode:Managed Channel:0 Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power=20 dBm Sensitivity=8/0
Retry limit:7 RTS thrff Fragment thrff
Power Managementff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
eth0 no wireless extensions.
frank@VGN-A195EP-PT:~Comment
I already explained that it is a verticle bar. It is on almost all QWERTY keyboards, on the same key as the \ (backslash):
That is also why I mentioned that you can copy and past the commands into the terminal.
Code:frank@VGN-A195EP-PT:~$ lsmod Module Size Used by tifm_sd 17566 0 joydev 17393 0 snd_intel8x0 33455 3 snd_ac97_codec 110213 1 snd_intel8x0 ac97_bus 12642 1 snd_ac97_codec snd_pcm 80916 2 snd_intel8x0,snd_ac97_codec snd_seq_midi 13132 0 snd_rawmidi 25424 1 snd_seq_midi snd_seq_midi_event 14475 1 snd_seq_midi pcmcia 39826 0 radeon 733914 2 snd_seq 51592 2 snd_seq_midi,snd_seq_midi_event snd_timer 28931 2 snd_pcm,snd_seq snd_seq_device 14172 3 snd_seq_midi,snd_rawmidi,snd_seq psmouse 96718 0 tifm_7xx1 12937 0 snd 62218 13 snd_intel8x0,snd_ac97_codec,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device tifm_core 15040 2 tifm_sd,tifm_7xx1 [COLOR="Red"]ipw2200 146210 0[/COLOR] libipw 46732 1 ipw2200 cfg80211 178877 2 ipw2200,libipw ttm 65344 1 radeon soundcore 14635 1 snd serio_raw 13027 0 yenta_socket 27428 0 pcmcia_rsrc 18367 1 yenta_socket drm_kms_helper 45466 1 radeon snd_page_alloc 14115 2 snd_intel8x0,snd_pcm lib80211 14040 2 ipw2200,libipw pcmcia_core 21511 3 pcmcia,yenta_socket,pcmcia_rsrc drm 197641 4 radeon,ttm,drm_kms_helper sony_laptop 39681 0 parport_pc 32114 0 mac_hid 13077 0 rfcomm 38139 4 bnep 17830 2 bluetooth 158479 10 rfcomm,bnep ppdev 12849 0 i2c_algo_bit 13199 1 radeon asus_laptop 23693 0 sparse_keymap 13658 1 asus_laptop input_polldev 13648 1 asus_laptop shpchp 32265 0 lp 17455 0 parport 40930 3 parport_pc,ppdev,lp usbhid 41937 0 hid 77428 1 usbhid firewire_ohci 40180 0 firewire_core 56940 1 firewire_ohci e100 36289 0 crc_itu_t 12627 1 firewire_core
Code:frank@VGN-A195EP-PT:~$ iwconfig lo no wireless extensions. [COLOR="Red"]eth1 IEEE 802.11bg ESSIDff/any Mode:Managed Channel:0 Access Point: Not-Associated Bit Rate:0 kb/s Tx-Power=20 dBm Sensitivity=8/0 Retry limit:7 RTS thrff Fragment thrff Power Managementff Link Quality:0 Signal level:0 Noise level:0 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0[/COLOR] eth0 no wireless extensions.
Now click (or right-click) on the Network icon in the system tray. It should show a list of available Access Points. Click on the one that you want to connect to.
EDIT: Heres a picture example:
http://upload.wikimedia.org/wikipedi...ager_0.9.5.pngLast edited by Time2Retire; 06-02-2013, 07:47 PM.Comment
finelly pays off,i was about to give up but you came along with all your pacience and help,i also did download some pakages from the restricted ubuntu software, don't know if that had anything to do with the succsses,whatever it was i don't know,but i'm good and i love this xubuntu desktop i love everthing about it.thanks again for your great assistance.Comment
It shouldn't be so hard. I think you are expecting it to be hard, so therefore it is.
You had to learn how to use Windows, so you will now need to learn how to use Linux. Don't give up so easily.Comment
