Are faulty capacitors the cause of many Asus A7N8X problems?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    I'm asking about why do many message boards have posts about Asus A7N8X motherboards having major problems?
    The reported symptoms range from POSTing problems to being unable to install the OS.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Hi and welcome to the boards.
    I personally don't have any experience with this particular motherboard. To check your caps, look at the brand first. Asus uses Rubycon caps on most of their motherboards, thus Asus is one of the few that had minimal problems with bad capacitors. I personally have only seen a couple Asus boards with bad caps. Post the brands of your caps and if they're showing any physical faults. That will help for diagnosing.
    Also, make sure you have the board flashed with the latest BIOS revision and the most recent stable drivers for your hardware.
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Well, I don't have an Asus A7N8X (nForce2) motherboard. I have an Asus A7V8X-X (Via KT400) motherboard.
      Arc A770 16 GB
      • Fatal0E
        • Jan 2004
        • 252
        A7N8X-Deluxe through 1.04 used Nichicon completely, the early revision 2 boards used a Rubycon and Nichicon mix. The newer boards use a Rubycon and OST mix.
        I love this board, until the OST caps started appearing. Posting problems can be due to a weak cmos battery (odd but seen it several times). Other posting and stability problems can be due to memory. Always had good luck with good quality sticks using Nanya chips, Windbond, and Infineon. Had issues with Samsung, Siemens, Spectek chips.
        • (In)Sanity
          • Feb 2005
          • 11
          I own an Asus A7N8X-Deluxe board ver 2.0. I love it.
          Things I've noticed,
          My 2800 Barton (multiplier unlocked) will run perfect @ 166 x 13.5 (2250) however it will not work at all above 170 FSB regardless of the multiplier.
          I normally leave it at the stock 166 x 12.5 speed unless I plan on a weekend of playing Desert Combat or such.
          Had to switch power supplies on this box a few weeks back, was becoming unstable. Asus Probe (monitor) showed a lot of fluctuation in several of the voltage lines. I went with an Enermax 420 Watt (blue) Noisetaker, system has been rock solid since.
          Caps are the Nichicon around the CPU and OST everywhere else.
          I love the nVidia chip set and the sound, most excellent.
          The Science Forum
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            even in the bios are your voltage lines stable after the enermax? every time i am repairing a comp with an asus i check the voltage lines and they are jumping about. even new boards but stable otherwise.
            clever to have your avatar changing all the time.
            • (In)Sanity
              • Feb 2005
              • 11
              Under load, no. Idle yes. The cheap PS was jumping around while idle. The system is FAR more stable then it was before I changed the PS. Actually it's not had a single issue since, even overclocked.
              The Science Forum
              • rugger
                • Feb 2005
                • 55
                I would be suprised if a significant number of problems on Asus A7N8X boads can be attributed to bad capacitors.
                Even the boards with OST capacitors, it is likely that such caps are not the low-ESR ones where they have been blowing up. While it would be nice if all the capacitors were of the highest quality, people don't want to pay the price.
