Ratdude's main rig V3, maybe
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    While I was on spring break I met up with Junk Parts... and he gave me a Tyan S2885 mobo plus 2 2.4ghz Opterons and coolers. The good news is that it is more powerful than my current maxed out Supermicro X5DAL-TG2 rig (and if not, it has the potential). The bad news is that it's EATX.
    The first small hurdle is that unbeknownst to JP, 3 of the 22 KZG caps on the board went bad while the board sat collecting dust! (and you though Sacon FZ was bad...) I already ordered caps... so for the rest of this post let's assume the board is recapped and working.
    If I were to build this into main rig V3, the following parts would be moved over from main rig V2:
    -GPU (it's the most badass AGP card I've ever owned)
    -HDDs and 3ware card (plus the 4th spare hdd pending case space)
    I may also move the following over
    -RAM (unless I find 8 or 16GB in 333/400)
    -PSU (unless I find a better fit or more powerful unit, or the case comes with something usable)
    -Opticals (pending case color, I have a white bezel for the lightscribe drive I could use)
    Anything pulled from V2 would have some functional replacement added, as V2 took so much work to make run and I'd like to see that it gets used elsewhere; it's too good to waste.
    In order to make it run, I for sure would need to buy:
    -EATX case with enough space
    -I/O Shield (JP didn't have it, he wasn't sure if Topcat ever sent it or even had it in the first place)
    -Front I/O adapter
    Possible upgrades:
    -CPUs (a pair of x2's would be nice)
    -RAM (already mentioned)
    -TV Tuner (if I could get one of the few QAM capable PCI cards)
    The worst part seems to be the EATX case... ebay was pretty much useless... at newegg, the best deal I could find w as this:
    http://www.newegg.com/Product/Produc...82E16811152168
    That would work... but $140 is a tad hard to swallow. Yeah, it includes PSU, but'ts only a 500W 80+ bronze... Going with that, I'd move over the lightscribe drive from the V2 unit and add this to 5.25" bay 2:
    http://www.newegg.com/Product/Produc...82E16820132021
    I don't like the e-sata (since my board has no e-sata), but the fact the the 3 USB ports + card reader has a hub built in is a huge plus (since the board only has one front USB header). Another plus is AC 97 support, which is needed for this board.
    I'd personally rather find a used server/workstation case and add an I/O adapter to that; however, it seems that ebay has nothing nor does anybody I know personally. Heck, I'd be willing to pay a decent chunk of change for a decent used case...
    Anybody have suggestions or comments?
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Ratdude's main rig V3, maybe
    All those boards had the IO shield, I had 8 of them at one time. I think 'ol JP just lost it in the shuffle, as the IO shield was included when I sent it. Those boards require reg/ECC memory. Anything less will not work!!
    I do like that case though!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      I see. Unless it turns up I'll ebay it.
      That's what I have 8gb of... and another 2gb of as well. If I could find some 8gb PC3200 4 stick sets for under $50 a set, I'd put 8 or 16gb in it. My PC2100 set cost $26, so maybe the faster sets aren't that much more.
      I don't like the price but it may be my only cloice... I also saw some gamer full towers with EATX support but they were $300 a pop and had too many front I/O ports. Not to mention looked too gamer like for my tastes.
      edit- the case already has 2 USB ports... so nix the front card reader since the board AFAIK only has one USB header. That blows...
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Scored 16gb RAM while looking for a an older server to steal a case from:
        http://www.ebay.com/itm/Server-RAM-K...item460e133703
        I bought two lots... So V2 will keep the 8gb DDR... and there is more where that came from so if anybody has a board that can run it, swipe it while you can. For $25 per 8gb, you can't go wrong!
        sigpic
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Same board I got from same source. Note: good luck getting SATA to work. Mine is in a box in the closet... have yet to build it in something. Considering a custom case for it!
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            More possible cases:
            http://www.hypermicro.com/ProductDes...-SERVER&key=it
            http://www.hypermicro.com/ProductDes...S-KHDHS&key=it
            Both have EATX space... but only 2 5.25" bays and no 3.5" bays, so if I ever need a floppy it will be a USB one. They do however have more space for fans.
            They're cheaper than the supermicro but they also are older and possibly more proprietary...
            Suggestions on either option?
            edit- Not using the onboard SATA, since I have a 3ware card. It has the same SATA chip as the V2's Supermicor X5dal0tg2; they are not optical drive friendly (not bootable, that is).
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              It won't turn up here, I sent it with the board, and I have none of these boards or any of their accessories remaining.
              $140 bucks for a high-end case WITH a PSU is too expensive?! That is pretty cheap actually! I've paid over a grand for cases, without PSUs.... Live a little!!
              If you're whining about a 140-dollar case, I'm sure you would have a conniption over this one....but I'm gonna throw it out there anyway!
              http://www.newegg.com/Product/Produc...irtualParent=1
              I've got 2 of these. Best cases I've ever had in my 20 years of computing experience!
              Team : 49813
              Join in!!
              Team Stats
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                I meant if JP came across it by random luck. I know you don't have any more.
                I'm just trying to get the most bang per buck. I may go ahead and order the case if the recap is successful as the hypermicro cases have too much mystery behind them (none of the pictures show what I want to see and they have no way to ask for them).
                If I was building a rig using newer parts, I would too. However, in this case, the cost for such ain't justified.
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  That depends on how you look at it. That case would house any hardware you put in it until they do away with the ATX form factor....which means that case will last you for the remainder of your PC building days....you'd never have to buy another one.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Those Lite-on built supermicro power supplies are really solid units. They aren't the most efficient, though, and also add greatly to the cost.
                    But as that board does not have a SLI capable chipset or even PCI-E, I would not worry about power consumption and use what you have now.
                    http://www.ebay.com/itm/Lot-of-2-AMD...item565457a58b
                    $15 for a pair of 285's is a pretty good deal which are the fastest supported according to this (http://www.tyan.com/archive/support/...n_opteron.html) site.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Bad News:
                      The mobo didn't survive the recap. It appears CPU socket #1 is toast... insert a cpu/cooler into the socket, and it won't post. Remove it, and it will. I've checked everything and all... I must have nailed a trace or something... My last AMD dualie board also failed a recap in the exact same way.
                      I guess I flushed $50 down the tube on RAM I no longer have a use for... Anybody need some 2gb PC3200 ECC DDR sticks or have a board to use them in?
                      sigpic
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        silly question, but did you make sure the CPU was good?
                        Team : 49813
                        Join in!!
                        Team Stats
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Sure did. Both CPU's work in Socket 0.
                          Me and AMD dualie boards don't mix?
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            After looking around ebay and the like, I've come to the conclusion that unless I can somehow make the motherboard run again, I'm better off to sell the RAM I ordered... I really screwed the pooch on this one.
                            Any other ideas? Anything?
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              what PSU are you powering this thing with? Do you have all the right connectors with no empty slots? If you're using a 4-pin plug in the 8 pin socket, it won't work. Same with a 20 pin plug in the 24 pin connector. One socket being dead is just odd.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                I was using the 24 +8 PSU out of V2, a cooler master silentpro 600W.
                                I suppose I could try yanking the PSU out my dad's rig (an acbel 550W), as that's the only other PSU I currently have in running condition that has the required ports and supply ability.
                                sigpic
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  How bad do you want one of these?
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Why, do you not want yours? If so, skype or PM me an offer.
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      From what I am seeing tyan did make all rubycon revisions of this board...Too bad the example on ebay is $80 w/o shield...
                                      sigpic
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        Bad News:
                                        Did you check to make sure that there are no solder bridges on other parts from loose solder splashing around?
                                        Btw, is there just one VRM for both cpus?
                                        Muh-soggy-knee
                                          ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 10:50 PM
                                          ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:05 AM
                                          ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 07:07 AM
