Old slot 1 pentium 2, What to do with it.
  • gilly1984
    • 751
    Just been given an old pentium 2 266mhz Compaq Deskpro.
    Is this too fast for mame stuff, old emus and stuff? It also has an Ati 3D Rage pro turbo AGP GPU.
    It has A massive 128mb sdram.
    10GB HDD.
    And a kitten? <<Not sure if that came as standard in these?
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: Old slot 1 pentium 2, What to do with it.
    That's the deluxe edition! Those are the only deskpros to come bundled with a free kitten
    If it works, it may do nicely for MAME emulation, The 3D Rage video chipset was a beast in it's day. I have a handful of these cards around.
    EDIT: I just had to do this. lol
    • gilly1984
      • 751
      Ha ha, cheers Hemingray.
      • gilly1984
        • 751
        Oh well, doesn't work.
        HDD led just flashes away, but the strange thing is when i remove the cpu the hdd spins up and it sounds like its starting up? Put the cpu back in and its quiet with the hdd led flashing constantly. Must be a dead cpu.
        • mariushm
          • May 2011
          • 3799
          Without CPU, the motherboard won't start, so the controller doesn't inhibit the hard drive from starting up through ATA commands.
          Don't rush so fast to decide the cpu is a problem, the video card might be faulty...
          • Hemingray
            KABOOM!
            • Jul 2010
            • 143
            Have a spare Slot 1 PII to try?
            • gilly1984
              • 751
              Dont have any slot 1 cpus, not seen one for about 10 years lol.
              I have another agp, but i'm not taking it out of the htpc. I will take the rage out and see if it comes on. No onboard vga though.
              • gilly1984
                • 751
                Nope, no difference with the card removed.
                Could it be that it has been sat for years in an old warehouse type of place, lots of dust on mobo, perhaps clean in the sink?
                • Heihachi_73
                  • 713
                  Reseat the RAM, remove battery (it's probably been dead for over 10 years!), power on without any drives connected, drag out another power supply for a test... Does the PC speaker beep at all?
                  Plenty of things to test before you quit and give it the Photonic treatment! "Disappointed! Where's my hammer?"
                  • gilly1984
                    • 751
                    PhotonicInduction, what a great guy, love watching his vids.
                    No beeps whatsoever.
                    Reseated all ram, believe it all not my dmm says the battery is fine lol.
                    Dont have a spare psu, but i opened this one up and nothing looks bad.
                    Tried all you have said but it just wont boot.
                    Ram is receiving power, so is the rage.
                    CD drive opens and closes when the cpu is pulled out, but wont respond when the cpu is plugged back in.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Sounds like a short on the board.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • Hemingray
                        KABOOM!
                        • Jul 2010
                        • 143
                        Related to this, I scored an older IBM Aptiva (233MHz K6 CPU) That does work, but the Windows install (Windows ME, go figure on this) is hosed. Does work to some extent though
                        • Logistics
                          • Apr 2007
                          • 721
                          Cram it into a tight enclosure and turn it into a CD/Media player.
                          Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                          • gilly1984
                            • 751
                            No way to put it in a small enclosure, even the mother board is massive, with another board slotted horizontal into it which has the atx connector plugged into it.
                            Its a tank.
                            May get the wd40 and toothbrush out
                            • gilly1984
                              • 751
                              Only 10.9v on the 12v rail. stuck in a psu from an old p4 dell and its fired up yay.
                              test on monitor soon see if I have video.
                              • gilly1984
                                • 751
                                Nope, still a no go, washed all the board and its made no difference.
                                Tried different psu and gpu but still wont start.
                                Will replace the 6 cpu caps next. Are they critical? As in uf has to be spot on?
                                • Hemingray
                                  KABOOM!
                                  • Jul 2010
                                  • 143
                                  still gonna bet on the CPU being done for...
                                  • gilly1984
                                    • 751
                                    I will change caps before buying CPU.
                                    It has been sat in a dairy warehouse for over 5 years so hopefully just the caps have died through age and the cold.
                                    • gilly1984
                                      • 751
                                      Cpu gets warm, tested all around the board and there is power going around it.
                                      Is it worth changing the caps on cpu?
                                      • totoagung2
                                        by totoagung2
                                        Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                                        Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                                        01-01-2024, 02:43 PM
                                        ACER Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro Veriton 530 Specification for Upgrade or Repair
                                        This specification for the ACER Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro boardview and Veriton Veriton 2800 - Intel Pentium 4 530, 512MB, 80GB, DVD-ROM, Win XP Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        09-12-2024, 03:36 PM
                                        Acer Aspire Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Acer Aspire Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) boardview and Acer Aspire 3 A315-35 15.6 inch Laptop - (Intel Pentium Silver N6000, 8GB, 128GB SSD, Full HD Display, Windows 10, Silver) schematic....
                                        09-07-2024, 01:00 AM
                                      • Lifeisfun
                                        Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                        by Lifeisfun
                                        Hi folks!
                                        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                        Eventually I discovered that it was related to moving the laptop.
                                        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                        I removed the board got one of those memory slot testers...
                                        06-04-2025, 02:26 PM
                                      • AidenX
                                        Asus P2B | Slot 1 + Pentium II | no power
                                        by AidenX
                                        Hello!
                                        I would like to repair this old motherboard that i bought weeks ago with some other old stuffs!
                                        Sadly it doesn't work.
                                        I tested the CPU, ram, etc with another slot 1 board and they are all fine.
                                        Probably there is a short on the board, no power at all when connected to the power atx supply.
                                        Also, the power supply works fine with other hardware, but do a strange noise after few seconds that is connected to this board...i think is all ready to explode! XD
                                        Here some measures from the power connector...
                                        06-30-2022, 08:49 AM
