Reading SD card IDs
  • japlytic
    • Oct 2005
    • 2086
    Reading SD card IDs
    I found that only an PCI (or host) based SD card reader can read the IDs on an SD card.
    As far as I know, USB card readers (often found in low-cost notebooks and netbooks) cannot read the IDs on an SD card.
    The IDs contained in an SD card can give information about its authenticity.
  • Christos Tsiligiannis
    Marian Trace Alpha sound card repair help
    by Christos Tsiligiannis
    Hello to the forum.
    My name is Christos, I am new to the forum here and i am posting from Greece.
    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
    So i tried asking for a schematic from the company and they would not give me one. Instead they...
    11-18-2024, 05:26 AM
  • Kemer
    Graphics Card mounting frame
    by Kemer
    Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
    As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
    I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
    What worries me right now is the possibility that...
    09-14-2024, 08:57 AM
    HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
    This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
    09-06-2024, 08:30 AM
  • FZG
    EVGA Nu Audio Sound Card - Not Working
    by FZG
    I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
    The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
    I found...
    03-07-2025, 11:44 AM
    Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
    The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
    The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
    10-23-2024, 03:26 AM
