Aspire 9300 keeps switching off
+ More Options
Posts
  • godfrey65
    • Feb 2012
    Hi All,
    this is my first post and would be glad of any suggestion for my problem.
    My Acer Aspire 9300 keeps switching off. Some times it will run ok for hours, other times I get from 3 seconds into POST up to a couple of minutes after the PO system has loaded then it just shuts off. First thing I did was to check for overheating. The fan is clear and working with no obstruction. I have Silver Artic paste on the heatsink. Also now the problem can occur at POST when the unit is cold. I replaced the motherboard last year due to the common GPU problem this board has and it has run well up until last week. This problem will occur running from mains only or battery only. I have done lots of searches for the problem but cant find any pointers where to start.
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Aspire 9300 keeps switching off
    just fixed an acer with same isues! new cpu did it on this one! went through all the heat issues ! heat gunned gpu an board all that an no go, new ram, hd . finnally found a cpu to test in it thinken it was not the problem, ususally when cpu's go,. they just die! not saying ii bank on that but if have another cpu to throw in for test, ..to get sys to run before that. was putting in front of air con for a while an keep it there! not the way to have to run it!!!! good luck!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      maybe that series has a voltage regulation issue, putting too much voltage over a long amount of time can *slowly* electrocute a cpu
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sounds more like a loose AC adapter plug fitting or battery connection.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Koda
          • Aug 2011
          • 317
          • Macedonia
          Memory would be my first thought, try running one stick at a time in different slots and do a memtest for 24 hrs. Also test the charger for voltage stability. try running it without the keyboard, dead keyboards can cause a whole myriad of intermittent problems. Check voltages with everest or some other app while the machine is running. Do a reset of BIOS. Report back with the results and we'll go from there. Remember - To every problem there is a solution involving a sledgehammer
          Guns don't solve problems. I'll take 12
          • godfrey65
            • Feb 2012
            Thanks for the replies. Will probably take a bit of time to get through the testing as the problem is intermittent. Will start by testing the memory, then the keyboard and then I can get a CPU from ebay for £3.50 for testing too. Will reply when I have run some tests using the suggestions given.
            • godfrey65
              • Feb 2012
              Quick update. Have changed the memory trying different banks too, the CPU, updated the BIOS and heatgunned the GPU. On all occasions the laptop ran for several days without a glitch then the problem would start again. Sometimes at POST, sometimes 2 hours after. Only one of the above suggestions I havent tried is replacing the keyboard. I have a spare mobo for this which had the GPU problem. I heat gunned the GPU a couple of weeks ago and got the graphics back so I think now I am going to swap the motherboards over. If the shutting down problem occurs with this mobo I will then try replacing the keyboard. Will have to go on Ebay and get some more thermal paste, almost out now.
              • nish_pinto
                The Adventurist
                • Oct 2011
                • 83
                • India
                Why would you need to change your keyboard btw?
                http://nishantpinto.blogspot.in/
                  03-31-2024, 02:12 PM
                  ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                  This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-12-2024, 03:30 PM
                  ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                  This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  ACER Aspire Aspire TC-885 I5618 BE Aspire TC i5-8400 Specification for Upgrade or Repair
                  This specification for the ACER Aspire Aspire TC-885 I5618 BE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-885 I5618 BE boardview and Aspire Aspire TC-885 I5618 BE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  09-12-2024, 03:28 PM
                  ACER Aspire Aspire XC-780 I8658 NL Aspire XC i5-7400 Specification for Upgrade or Repair
                  This specification for the ACER Aspire Aspire XC-780 I8658 NL can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-780 I8658 NL boardview and Aspire Aspire XC-780 I8658 NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
