Recommended Server OS
  • shadow
    • Feb 2007
    • 732
    I currently have a low powered server which runs 24x7 mainly for home theatre purposes along with centralised file storage and file downloading. I initially got it up and running reasonably well with Ubuntu Server 11.04. However the configuration is not quite up to my liking (although it is almost perfect for my needs). The main reason for that is that I am not totally familiar with Linux and had to learn a lot of things along the way. I also found out that Webmin really is not that brilliant of a centralised system configuration software (if there is a better one which works well then please recommend it ). Along with that, I do not have a proper backup solution at this stage (which is asking for trouble at some stage).
    Therefore when I buy a pretty big external hard drive (which I will use for a periodic backup of the contents of the data on the server), I am willing to reformat the server and start from scratch (although it is not really necessary strictly).
    The important things I have setup at the moment are:
    Serviio - DLNA server to share video, music and images over the network (mainly there to be used by the television or to my laptop where buffering over SMB does not work particularly well).
    Samba - Convenient file transfer interface over the network for Windows and Linux clients.
    Saned - I am running the saned backend on the server so each PC on the network can utilise the scanner from anywhere.
    mdadm - Software raid on Linux. I have configured RAID 10 over 4x2Tb hard drives. Linux does not support the inbuilt RAID controller on the system (however I doubt it is that good or any better anyway).
    FTP - SMB (via Samba) does not seem to be the best file transfer protocol over a wireless connection. FTP file transfers seem to work much more reliably, is a bit faster and it has built-in resume functions (useful when wireless connection drops or when transferring big files).
    Transmission - Centralised BitTorrent server so every PC on the network can control torrents.
    PyLoad - Centralised web based file downloading application (useful when downloading from certain free upload websites and for downloading large files).
    I wanted to try out Oracle DBMS on my Linux box for R&D purposes, however I found out that it is really difficult to get going on Ubuntu and especially on Ubuntu 11.xx. This is the main reason why I am willing to try out a different server OS, one where installing Oracle will not be so incredibly painful.
    Therefore I need to make a reasonably important decision. Which server operating system should I use?
    I have been thinking about sticking with Ubuntu Server and this time doing all the configuration on my own (without Webmin at all) or using specialised configuration software which actually works pretty well (SWAT for Samba? for instance) or to try out CentOS. Although I am open to other alternatives.
    I am also open to ideas on better ways to configure a Linux (or other) server.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Recommended Server OS
    I'd run debian on it with a decent RAID card... a used 3ware/LSI one would do.
    debian is like ubuntu server only lighter and more stable (if you stick with stable).
    sigpic
    (Insert witty quote here)
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      correction: ubuntu is like debian, since its a debian distro
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        ubuntu is nooberized debian.
        PS- "like" can be used both directions, so I am still right.
        sigpic
        • shadow
          • Feb 2007
          • 732
          For those that are interested in what hardware I am running on.
          I managed to buy a HP Microserver for a very good price about a year ago. I am very impressed with the unit. It is small, low powered, solidly built and quiet. Even with 5x hard drives in it, it still only consumed around 60W of power in total. I find that pretty impressive and ideal for a small server to be running 24x7.
          Hardware Specs:
          Dual Core 1.3 GHz AMD Athlon II
          8gb DDR3 RAM
          1x250gb hard drive (system drive, useful as base hard drive when using software RAID)
          4x2tb hard drives (RAID 10 configuration)
          HP Remote Access Card (useful when running the system hidden away somewhere or running without a keyboard, mouse or monitor)
          As far as I know Debian Server and Ubuntu Server are very much the same. Am I correct?
          The only differences I could find are the software versions are older with Debian (which is rarely updated anyhow) and things like Ubuntu introducing Upstart.
          • shadow
            • Feb 2007
            • 732
            In the desktop editions yes. However does this apply to the server editions?
            Ubuntu Server by default has no window manager of any kind and just installs common packages (perhaps more than Debian Server?) and it is up to the user to install and configure everything from scratch using config files. Does not seem 'nooberized' to me.
            However perhaps it is my misconception.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Well, even the server version is nooberized to a degree... there are certain things that come pre-setup... The last time i tried it some things didn't work... Debian server fixed them all and once I got it setup it has been flawless.
              sigpic
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                I don't know what problems you are having with webmin. I use it on my ubuntu server and it works just fine
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Webmin is an ugly crap
                  I personally use Ubuntu sever over Debian, I just like it better...
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    for a personally administered server, I like webmin, I don't care how 'ugly' it is.
                    • shadow
                      • Feb 2007
                      • 732
                      In my experience, Webmin made some things easier to a degree. However in the end, the GUI just was not good enough to make a configuration exactly as I wanted. I got it pretty close and then had to manually edit the configuration files (mind you it is more convenient editing configuration files manually on a multi-line text field on a webpage rather than using 'vi' or similar). The Linux RAID module in Webmin just didn't work that well and I am quite unhappy on how Webmin behaved with regards to it and half of the applications I installed were not supported by Webmin and I had to administer then myself anyway.
                      Anyway back on topic. Neither Ubuntu Server nor Debian Server would really make it any easier to install Oracle. Actually perhaps easier than Ubuntu 11.xx as that is a real pain.
                      • smason
                        • 1652
                        I use Centos on all my Linux-based servers. Stable, and not bloated, and not dumbed-down like some distros.
                        I only use Webmin to manage mysql, as I'm a bit SQL-Illiterate. Everything else I just edit the .conf files.
                        • tsavpyn
                          Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                          by tsavpyn
                          Dear all,
                          I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                          Now I have a problem that I am unable to dump my BIOS into bin file.
                          My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                          I searched for FPT but there is no Linux version and none of them work.
                          I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                          I would really appreciate it if anyone...
                          05-28-2024, 11:18 PM
                        • ivtec
                          install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                          by ivtec
                          Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                          01-17-2025, 12:54 PM
                        • abajor
                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                          by abajor
                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                          04-23-2024, 11:43 PM
                        • omega
                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                          by omega
                          Hello all,
                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                          02-09-2024, 03:34 PM
                          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                          09-06-2024, 11:39 AM
