MSI x1800xl 512Mb (actually an xt)
  • Super Nade
    • Jun 2006
    • 294
    Guys, what caps are on this one? I see only 2 big caps (Aluminum?) on the card. The rest are surface mount. I am concerned about those caps as the fall directly under the stock HSF. The only markings on the caps are G3,100, 16V.
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • Super Nade
    • Jun 2006
    • 294
    Re: MSI x1800xl 512Mb (actually an xt)
    Forgot to add that the picture is courtesy of homer77 at ocforums. I have the exact same card which is NIB. Still waiting for my PSU.
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Abit IP35Pro
    ATi HD4870
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
