dell d620 not charging
  • hanifhalai
    • Mar 2012
    • india
    Dear sir,
    i have dell latitude d620 laptop. it working ok. but while i plug in adapter laptop change on adapter. in bios battery status indicate battery is charging but charging percent not increase. i checked battery and charger in other laptop, both are ok. what i do please help.......
    thank
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Thomasraud
    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
    by Thomasraud
    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
    QUOTED
    -It works on charger (without battery connected-only charger)
    -It works on battery (without charger connected-only battery)
    -& it also works when plugged in battery & charger, but it's not charging the battery
    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
    and..
    QUOTE
    The IC cannot maintain the input current level
    06-28-2022, 06:47 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • Grucha98
    Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
    by Grucha98
    Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
    Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
    09-09-2024, 11:22 AM
  • Robocop
    Dell G3 3579 (LA-F611P) not charging
    by Robocop
    Hey guys,
    I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
    In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
    06-25-2024, 08:15 PM
