Hotrod Dell Precision470 (paxville core processors)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Just for Shovenose.....more XP, Netburst, and Firefox!!
    As some of you know, I've been cleaning my attic, pulling all kinds of interesting things out of there...
    I've had a Dell precision up there since I did the remodel, I took it out of service a couple years ago, as its duties were off'd onto another machine. So yea, no big deal....it was a dual SL7ZF (3GHz Irwindale single core, 2mb cache)...was a decent machine for a netburst wonder....well in the process of my cleanup, I found a couple interesting CPU combos... First is a pair of 3.6GHz Irwindale core QAMW, which is a pair of engineering samples....unlocked multiplier!! They ran in the 470 @ 3.6....but Dell and their denutted BIOS didn't allow for any tweaking....so meh... I then came into a pair of 2.8GHz SL8MA 4mb Dual core Paxville core Xeons.....hmmmm Keeping in mind that the Precision 470/670 was never intended to run dual core or paxville core CPU's, the searching I did yielded more negative than positive results. It seems some boards would run them, some wouldn't...it was a crapshoot, so I didn't have much hope that it would do anything....but being attic junk, I figured what the hell and stuck 'em in there.... This message is being posted from it... It's dual core WITH HT....so its showing 8 cores. For netburst (and dual core at that), they're running pretty cool actually, but noticeably warmer than the single core CPU's...and the machine is snappier than I ever remember it.... Theres 8gb of RAM in it and a 7600GT video card....and for the XP lovers, x64. Not bad for an attic find!! I have no idea where these processors came from, probably a goodie box somewhere over the years.... Hail the free quadcore system!! I did have to recap it....like 3~4 years ago when it was given to me...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Hotrod Dell Precision470 (paxville core processors)
    I don't think my Tyan Thunder S2603 with two S603 Prestonia Xeon 2400DP's (SL6K2) and 2GB PC800 RDRAM can keep up with that
    lol
    Imagine what a sys like that would've cost you when it was new... omg
    edit: the above stuff is from/in a HP x4000 Workstation
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Nice find, I have a Precision 470 with a Paxville CPU too (just one though)
      I use it as a test server for Techspot
      If you fire up CPU-Z you should be able to confirm that your board is a "XC838"
      It will be listed under the "mainboard" tab and section "model"
      Here is a lengthy thread I made for mine, it was much harder to fix it, in the end I had to replace the mobo to support the Paxville CPU anyway...
      https://www.badcaps.net/forum/showth...light=paxville
      Do those other Xeons you had with L3 cache work in it?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Sure enough, it does. 0XC838 is what shows for model.
        Ohh I wish, I tried them. I got turbo fan syndrome. I never knew those cpu fans would spin so fast! You would lose a finger if you stuck it in there. It was blowing screws off the bench onto the floor, and papers all the way on the other end of the bench (bench is 11ft long). Everything I've found about the Tulsa cores, they're intended for a quad socket setup....and there are no dual boards that support them....
        Team : 49813
        Join in!!
        Team Stats
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Ok, thanks for trying atleast.
          Yea I had the same experience, as I did not google enough I bought 2x SL8UD processors and the fans ran at 100% with those, no POST either...
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            I found 6 pairs of xeon processors in this box. Several pairs found homes in other random boards, but I've still got 3 pairs left (the engineering samples, the Tulsa's, and the original Irwindale 3GHz that was in the precision to begin with). I found 2 pair of 3GHz Gallatins, but I had a couple boards for those. I figured if I can get them mated up with working boards, it'll be much easier to find them homes. The Prec470 is a keeper though.
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              NICE SCORE!
              What are you doing with this one? new main rig?
              sigpic
              (Insert witty quote here)
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Probably end up on the workbench out in the garage. My main system would murder this thing....but this is still a mighty potent Dell!!
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  ironically, it would murder my main rig... so your main rig would 2x murder mine?
                  sigpic
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    ...but you get Supermicro brownie points....Dude, I got a Dell....haha
                    FWIW, I found my stash of full sized AT style keyboards. function keys on the side and top, as well as. Almost impossible to find now.... I have to learn to type on one all over again....
                    Team : 49813
                    Join in!!
                    Team Stats
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I have a classic zenith one with the buttons on the side only... not sure if it works (it didn't like my 286 based zenith supersport portable).
                      btw, it may be a dell, but alt least it is a pro grade dell... if it were consumer crap, it would be different
                      sigpic
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Haha topcat if ur running Firefox 4 or newer i am happy :-) lol congrats on the good find!
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          FF10...that should make your day!
                          The machine is just chuggin' along.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Whats wrong with 11 :P
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              it bitched about my status4evar addon
                              Team : 49813
                              Join in!!
                              Team Stats
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Oh lol
