Serial to PS/2 adapters
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Yesterday I aquired an old IR Mouse/Keyboard set...
    the issue is that while it uses PS/2 for the keyboard, it uses serial for the mouse.
    this is fine for windows, but for linux, its a PITA at best... I couldn't get it to work despite my best efforts.
    What I would like to know is whether they make serial to PS/2 adapters... I know microsoft made one at one point and that the linux tool I was able to get to work reports the mouse as using the intellimouse standard...
    sigpic
    (Insert witty quote here)
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Serial to PS/2 adapters
    By the millions, check ebay.
    Serial mice are pretty old tech and required drivers.
    Old enough they might have dropped the drivers out of the Linux distros.
    (PS2 has a chip just for mouse/keyboard. Serial doesn't. With serial the driver does the 'translation' the PS2 chip would.)
    If you check around someone has probably updated an old driver to work with the newer distros.
    Mann-Made Global Warming.
    - Dr Seuss
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I'll poke around and see if I still have one. If I do, I'll send it along with the other stuff (as soon as I can get time to box it up and ship it...)
      Ludicrous gibs!
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        I think a serial to PS/2 adapter is less likely to work in Linux than just a plain serial mouse.
        Also, while I have seen a Serial PORT to PS/2 MOUSE adapter I have never seen a PS/2 PORT to Serial MOUSE adapter.
        Might be better off playing with your Linux some more. Did you try something like this? http://ubuntuforums.org/archive/index.php/t-23926.html
        -David VanHorn
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Obviously you never had a reason to look.
          They are common.
          http://www.ebay.com/itm/330680318428
          http://www.ebay.com/itm/110818011433
          http://www.ebay.com/itm/150631929125
          http://www.ebay.com/itm/130562319221
          - Dr Seuss
          • brethin
            • Dec 2008
            • 1907
            Or you could just drop a serial port card in the machine.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4951
              • New Zealand
              No, I guess I didn't. Interesting!
              -David VanHorn
              • bluto
                • Oct 2007
                • 560
                Read the fine print in the ebay listing:
                PLEASE NOTE: This product will only work with combination mouse, a mouse electronically designed to work with both serial and PS/2 applications,
                Your mouse has to have the appropriate guts inside it for this to work. The 'converter' from the first ebay link is strictly passive. In other words it only converts pins from one connector to the other.
                Mice that supported both typically had a switch on the bottom to tell it what kind of port it was being hooked up to. I think there is one at the office that I can snap a picture of if you don't believe me.
                Edit: found some pictures (attached - site is slow)...
                http://www.recycledgoods.com/product...MS-Switch.html
                Also found a link for an industrial solution. Should work with any serial mouse. Although probably more that you want to spend:
                http://www.vetra.com/327text.html
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  its an SW issue... it has nothing to do with serial controllers. not to mention the computer has NO free PCI slots (its a shuttle xpc st61g4 with the 2 slots taken by an AGP card and a TV tuner)
                  it emulates a MS intellimouse if that means anything (the linux tools said it needs the intellimouse serial driver, not the standard mouse serial mouse driver)
                  from what I have read, it probably isn't convertable so, yup, i'm screwed.
                  EDIT:
                  WAIT- there is hope!
                  my set is one of these:
                  while finding that I found this pic of the receiver:
                  sounds like if I can find the right adapter, I am in luck.
                  sigpic
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    Maybe one of those standard adapters would work, then.
                    -David VanHorn
                    • bluto
                      • Oct 2007
                      • 560
                      Yea looks like it would be worth a try. I thought I had one to give you but it is the wrong gender variety...
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        I have one of those...
                        sigpic
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4951
                          • New Zealand
                          As do I
                          -David VanHorn
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Here's the full poop.
                            The Serial Mouse uses a RS-232 style interface with -5 to -12 VDC as logical 1 and +5 to +12 VDC as logical 0.
                            The PS/2 mouse interface is a TTL-style interface, which uses 0 - +2 VDC as logical 0 and +3 - +5 VDC as logical 1.
                            In addition the RS-232 is an asynchronous interface, the PS/2 interface is a synchronous, where the data is sent along with a clock signal. It uses a simplified 4-wires serial interface with +5VDC (for the transceiver), GND, keyboard / mouse clock and keyboard / mouse data. The data and clock line can be used from the keyboard / mouse controller and the attached device as well following a particular handshake, which defines which is the active sender and which is the receiver.
                            So: it is not *that* easy converting serial mouse to PS/2 and vice versa.
                            The dual mode mice have an automatic logic detection and form of adaptive electronic interface, which detects whether the mouse is attached to a serial port or a PS/2 port and sets the output drivers accordingly.
                            I've only seen really old or really cheap mice not work for both.
                            That said.
                            Except for temp/work-bench use I've used the same make/model mouse since the 90's and it works with either interface.
                            [Only one I've found where my hand never ever gets tried. My exe had carpel tunnel and it's only one that she didn't have problems with too. Every time I see one cheap on ebay I snag it.]
                            - Dr Seuss
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Still looking, I may have to bite the bulled and play the fleabay lottery...
                              sigpic
                                DELL OptiPlex 7050 OptiPlex 7000 i5-7500 Specification for Upgrade or Repair
                                This specification for the DELL OptiPlex 7050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7050 boardview and OptiPlex 7050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:36 PM
                                Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                This specification for the Acer TravelMate P214-52-566U+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+15.6" Bag&Mouse boardview and P214-52-566U+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-06-2024, 07:20 PM
                                Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                This specification for the Acer TravelMate P215-52-56G5+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+15.6" Bag&Mouse boardview and P215-52-56G5+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook P2 Specification for Upgrade or Repair
                                This specification for the Acer TravelMate P214-52-54NA+15.6" Bag&Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-54NA+15.6" Bag&Mouse boardview and P214-52-54NA+15.6" Bag&Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                HP ProBook 430 G7 + Elite Presenter Mouse Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G7 + Elite Presenter Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Elite Presenter Mouse boardview and 430 G7 + Elite Presenter Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-06-2024, 05:00 PM
