Two faulty Radeon 5970 cards
  • oleq83
    • Jan 2012
    • 4
    Hello.
    I've been searching a bit on the net and there seemed to be a lot of people with with good technical insight on this forum, so I was wondering if anyone could help me with two faulty graphic cards that I purchased recently.
    So. I recently purchased two used Radeon 5970 cards for cheap.
    I was told by the previous owner that the cards had stopped working after his PSU had all of a sudden started sending out 16v on the 12v lane, causing his motherboard and both the graphic cards to stop working.
    He suggested that the problem was propably due to broken Volt Regulators on the cards and it shouldn't be too difficult to replace. I have a hot air station and have replaced mosfets and a few smds earlier, so I thought it wouldn't be too hard to replace the Vrm chips.
    When I received the cards I first tested the cards in my computer, to see what happened.
    The first card got no signal on the screen and the fan was running at 100%. But even though the card didn't output any signal, the computer continued to boot into windows, as if everything was working just fine
    The second card also did not output any video signal. This card however, the fan was running at stock speed. But here also, the computer continued to boot as if nothing was wrong.
    So, I dissassembled the cards, to see if there was anything visibly broken on the cards. But as far as I could see, nothing seemed broken.
    I then noticed these Vrm chips and they did not look at all like what I was expecting. I was expecting to see something like mosfets, or transistors or something, but in stead, there where nine tiny chips on the right side and at the top of the card.
    So I realise that I've propably gone in way over my head here and that these cards should propably be looked at by proffessionals, but I was just wondering, could it be as easy as to just replace these chips and the cards would be up and running again?
    Cause if so, then I think I should be able to replace them with my workstation as long as I can find the needed parts somewhere
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Two faulty Radeon 5970 cards
    It's possible, but not highly likely.
    Do you have a multimeter? If so, start checking the MOSFETs for short circuit between Source and Drain. Keep in mind that some MOSFETs may apart shorted due to surrounding components in the circuit.
    If you're not sure what I'm talking, just post some pictures of the cards here (use the "Manage Attachments" forum feature for that) and we can tell you what to check.
    • severach
      • Aug 2007
      • 1055
      Since all regulators have a capacitor on the output, checking the capacitors for shorts is sufficient. Short testing is done on the diode or low resistance scale with the equipment unpowered. Capacitors are easier to identify and less confusing to test than MOSFETs. Read the meter carefully. Many meters beep when the diode drop voltage is less than 0.075v because that would usually be considered a short. On a high current low voltage GPU or CPU that is a perfectly normal reading in some places. Shorts tend to be 0.008v or less and some DVM do not measure that low properly.
      Voltage regulators are tough and hard to burn out. It's their job to take an uncertain input voltage and put out a definite output voltage. 16v into the many linear and PWM regulators many of which start with 12v shouldn't be a problem.
      The big ATI 5970 chip is the high risk. It is fed by many distinct voltages ranging from 3.3v to 0.85v that come from the many regulators around the board. Many of the chip's voltage inputs are very sensitive and a bit too much is enough to short the internals out. There isn't much on a video card that 16v on the 12v line would damage because 12v is used entirely for voltage regulators. None of the card runs at 12v.
      Since the cards run, you can also test the capacitors for voltage with the equipment powered taking care to not short anything with the leads. Write the voltages down along with the capacitor voltage rating and you may see patterns emerge. A shorted regulator MOSFET would result in a capacitor with zero volts like a shorted GPU or linear regulator would result in one of the lower voltages shorting to one of the higher voltages.
      I think the power supply did much more than jump to 16 volts before the end. A highly unstable 12v can trick the many regulators into producing voltages they aren't supposed to.
      sig files are for morons
      • oleq83
        • Jan 2012
        • 4
        Ok. Thanks a lot for the reply guys.
        Hmm. I guess there's a lot of different components that could be broken then.
        I took some pictures of the card. I decided to start of with the card which had the fan at stock speed.
        When I looked over the card, I noticed that one of the components (I think it is a capacitor) looked a little dirty, so I used my cheapo usb microscope to get a clooser look at it. As you can see in the pictures that I have included, the capacitor on the right side, had a thine "line", running across it. I tried to pick at it with a tweezer, to see if it was just a piece of hair, or something else, that had been placed on the component. But when I picked on it with my tweezer, I discovered that it was in fact a small crack.
        So, I tested these three capacitors, or components, using the diode function on the multimeter.
        Using the positive probe from the multimeter on the left side of each component, I got these readings. Starting from the left: 0.648v, 0.000v, 0.217v.
        I compared these readings with the other card. On the other card I got these readings. Starting from the left: 0.669v, 0.669v, 0.702v.
        Could this mean that the voltage regulators for the two capacitors which had different readings are broken?
        And could this also mean that the Gpu's could have gotten too high voltage, causing a short inside the gpu?
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          That ceramic capacitor is indeed bad. Ceramic capacitors tend to go short circuit when they go bad. Remove it from the board.
          Looks like the middle and rightmost ceramic capacitors are bad. However, these may not be the only bad ceramic capacitors on those rails. If you look above them, you will see other smaller tan-colored ceramic capacitors - those can be bad too.
          What to do: remove the ceramic capacitors that are showing 0.000v and 0.217v. The use the diode test function on your multimeter again to check the spots where those ceramic capacitors were located. If you still get the same readings, then you haven't found the shorted capacitor(s) yet. In that case, keep looking with your multimeter for capacitors that show the same 0.000v and 0.217v readings. Once you find all (or as many as you can) capacitors like that, see which ones look the most dodgy and burned and remove them.
          Also, don't throw away the capacitors you remove yet. Check them with your multimeter on diode test function instead. If they show open-circuit (multimeter acts as if you have nothing connected across its test leads), then the ceramic cap in question is likely fine.
          Can't tell from the measurements you did. First remove the ceramic capacitors that appear shorted, then we will see.
          Maybe, maybe not. Most likely no.
          This is a bit like the lottery, yes, but you get some learning experience from it.
          • skeeter105
            • Dec 2012
            • US
            Hello, I have several Radeon 5970s with this exact same issue. I was looking at replacing the capacitors as they appear shorted when testing them with my DMM. The issue i'm having is i'm unable to figure out what size and type of capacitors I need to replace them with as they have no identifying marks. Dose anyone know what caps I need to order to replace these or any suggestions on how to identify what size these caps are?
            Thanks,
            • bravo-tel
              • May 2013
              • Serbia
              10nf
              • chrle
                • Sep 2013
                • 158
                • slovakia
                hello,I have radeon 5970,when I power up my pc, fan is blowing 100% ,no signal ,and 2 red dieodes are lighting. what could be problem?
                I have 1000w corsair power supply.
                  AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                  The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                  10-01-2024, 12:46 PM
                  AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                  The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                  10-01-2024, 01:07 PM
                  AMD Radeon RX 470 / RX 580 Schematic & Board View
                  The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                  10-01-2024, 12:52 PM
                • Byte_76
                  Faulty XFX Radeon RX6800 Merc 319. (Non-XT)
                  by Byte_76
                  I have an XFX Radeon RX6800 which allows me to boot into Windows but as soon as the drivers load, the screen turns off and I get an orange LED.
                  I tested the card as a secondary adapter and found that when the drivers load, GPU-Z indicates 0MB on the memory and a 0Mhz core and memory speed.
                  I created a Linux boot stick and ran a training check with the Radeon test software and it reports no errors on the memory.
                  This same test on another Radeon RX6800 with a known bad memory module does indicate the faulty module.
                  What could be wrong with my XFX...
                  01-29-2025, 01:33 PM
                  AMD Radeon R7 340 / R7 430 Schematic & Board View
                  The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                  10-01-2024, 12:36 PM
