Capacitor Lifetime
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Capacitor Lifetime
    I'm a bit confused on this...
    -Whats the general hours of lifetime on common capacitors (Nichi HM/N for example)?
    -If that's at 105C, is it true it doubles at every 10C decrease?
    -if a PC is on 24/7 that's about 720 hours a month. That's about 8640/year
    -If a cap is rated at 10000 hours, that poses a serious issue.
    Reason I'm asking:
    -I've got 4 PCs in my closet. Running 24/7.
    -3 are AMD Athlon 64 X2-based, running folding@home SMP, 1 is my file server and one is a minecraft server. These have a mixture of good caps and bad caps (KZG, mostly)
    -1 is a Dell Dimension 4600, P4HT 2.8, running folding@home uniprocessor and also a minecraft server. This one has some Nichicon (HM i think) that are in the bad date codes(I've checked)
    -I push my servers hard. As mentioned previously, all are at FULL CPU LOAD 24/7. They're in a closed closet with no cooling. They are all right next to each other. I'm tellin' ya, it's HOT in there - if I open those closet doors I can walk around in a T-shirt and shorts in my room, even when it's raining outside and my windows's open - I never have to turn on a heater...
    My primary question is: how long can I expect them to last. How long should I expect the capacitors to last?
    I haven't had any stability problems at all, no BSODs, no overtemp shut-offs, so I'm tempted to say the caps are all fine (each server was visually checked for bad caps in mobo, PSU, and graphics card before being put into server)
    Also, what can I do to make my servers happier?
    Additionally, should I worry about the PSUs? They are all 200W-300W OEM/generics. Models: "GPS" 300w (Enhance built I think), Dell (either 200 or 250W), Lite-on 250W, and Bestec 300w...
  • c_hegge
    • Sep 2009
    • 5219
    Re: Capacitor Lifetime
    Typically, a cap is rated at 2000hrs at 105*C and at the maximum rated ripple and voltage. every 10*C below 105*C doubles that lifetime. The fact that the cap won't be run at their maximum rated voltage and ripple will further increase the lifespan.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I see... with those factors combined can I expect 20000 hours out of a capacitor?
      • c_hegge
        • Sep 2009
        • 5219
        Probably, if not more. there's a reason why I still see pentium 2s and 3s with perfectly good caps (when they are good brands, that is).
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Alright, makes sense - now, should I be more worried about the motherboard or PSU caps?
          • retiredcaps
            • Apr 2010
            • 9271
            If you have servers that have peripherals like floppy drives, cd-roms, modem cards, etc and don't need them, disconnect their power molex so they don't add to the heat generation.
            It may not be much, but every little bit helps?
            --- begin sig file ---
            --- end sig file ---
            • mariushm
              • May 2011
              • 3799
              Read section "Useful life"...well, you can read all as it's useful info but this section on pages 8-10 explains your question :
              The number of hours doesn't say the capacitor has a "warranty" of 2000 hours and then it may die.
              For non-solid aluminum capacitors the influence of temperature on useful life is approximated by the so-called ‘10 K-rule’. The ‘10 K-rule’ states that double the life time can be expected per 10 K temperature decrease; this principle is derived from the well known law of Arrhenius about acceleration of reaction processes.
              The exact temperature dependence of useful life for a particular range is given in the corresponding detail specification in the ‘life-time nomogram’ (‘Multiplier of useful life’ graph in the detail specifications). Detailed performance requirements, on which the definition ‘useful life’ is based, are also stated in the relevant detail specifications.
              Exceeding those requirements shall not necessarily induce a malfunction of the equipment involved. The performance requirements offer advice on the choice of components and
              design of the circuitry.
              Based on the Arrhenius law and on experience for some decades, a nomogram is specified in the detail specification for each range, where the influence of ambient temperature and ripple current on the expected useful life is shown. Ripple currents at other frequencies than specified must be corrected using the frequency conversion tables in the relevant detail specification.
              So how much a capacitor will stay within specs depends on how much ripple introduces heat and how much the temperature around it stays low.
              Page 10 has some examples on how to estimate how much the capacitors will last. Do note that those charts with the multipliers are "typical" ones and some capacitor series may be better or worse than those but the paper gives you a good idea on how to determine.
              Floppies and cdroms and all that are basically dead when not in use, they don't generate heat. Don't bother removing power from parts and all that.
              The server will be more likely to fail when you reboot it once after keeping it on for a long time - the inrush current in some component may trip a fuse or burn something or the mechanical parts of the hard drive may fail even though it kept spinning for months/years.
              Best thing you can do for hardware is to keep the temperature stable and average, not high or very low. High temperature hurts but so does very low temperature - don't go overboard. Just open it up and blow the dust once in a while and you'll do fine. The power supply is more sensitive to heat and that along with the cpu cooler fan would probably die first, if the hard drive lasted already a few months of use (majority of hdd failures are within 1-4 months of use).
              later edit: my advice would be to cut down on the folding at home ... those processors are slow enough that your contributions are ridiculously small - what your system does in a day is probably done by two quad cores/i7 in a couple of hours. Overall your contribution is insignificant but you're damaging the hardware with heat and spending money on power.
              In fact you can probably spend 40-50$ on ebay on a cheap nvidia gtx 260/ 4850/5450 and use it for folding on gpu and get better scores than those old systems together.
              • c_hegge
                • Sep 2009
                • 5219
                Of course, though, these rules assume good caps. With a bad cap like KZG, you won't get long at all. If they were brand new when you got them, you'd be lucky to get 1 year out of them in a hot environment
                EDIT: If you have any GSC/Sacons in there, you'd be lucky to get two months.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Alright, I measured, my closet is about 82 degrees
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    No.
                    The 'Lifetime' in data sheets has nothing to do with 'useful' lifetime.
                    It is called 'Load Life' or 'Endurance Lifetime' among other things.
                    No cap manufacture makes a claim about [or spec for] 'useful' lifetime.
                    The lifetime in data sheets is basically how long you can apply max voltage, max ripple, and max temp at the same time and the cap will still be in spec when returned to nominal conditions.
                    - Nothing says for how long it will stay in spec afterwords.
                    If your actual conditions are max voltage, max ripple, and max temp at the same time then you have other problems.
                    It's not a real world condition.
                    Here is the tricky part.
                    Because Useful Life and Load Life are dependent on the same factors they are proportional.
                    - So if you change temp and double one, the other will be doubled also.
                    Nichicon VR [85C @/2000Hr] start going bad after about 4-5 years 24/7 in poorly cooled cases.
                    A 105C @/2000Hr cap should last 4x as long in the same conditions, so, 16-20 years 24/7 in a hot case.
                    IOW: Use 105C caps, descent cooling, and don't worry about it.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Alright. So say I'm running a Rubycon MCZ capacitor on a motherboard VRM, right next to a hot CPU, so the capacitor might be at...hmm... 90C. There's a decent quality PSU that's outputting clean voltage to the VRM. All in a tiny HP case. How many hours can I expect out of that capacitor in that configuration?
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Given the room itself is over 80F probably close to what you'd get with a Dell Clam-shell Optiplex.
                        Can't tell you anything for sure.
                        No one can.
                        The only thing you can actually ~DO~ is try to keep the closet cooler and/or rebuild into a better cooled case.
                        - Dr Seuss
                        • ThePCDoctor
                          Retired Tech.
                          • Sep 2011
                          • 59
                          A point of info about the PSU's formerly mentioned......
                          Not long ago, I emptied my junk box of 14 bad PSU's.
                          All but two of them were Bestec 300 W. The other two were cut-rate brands I found at computer shows. Neither one lasted more than a year in service.
                          (All of them, had those bad Chinese cap's.)
                          The problems? All had multiple bulging and leaking capacitors.
                          I recently took a Bestec 300W out of a working desktop PC and opened it up to check the caps. One was seriously bulging, but the supply still worked. So I ordered a replacement cap from "Badcaps.net" and I've since replaced it and put that supply back into service, in one of my test PC's.... the one I'm currently testing windows 8 DP on. With a Bestec PSU, that PC will never leave my shop, unless it's in a garbage bag.
                          Does anyone know, if there's a brand of PSU that uses a new style of cap that will never bulge or leak.
                          One motherboard manufacturer claims to have such capacitors. Supposedly Good for the Life of the board.
                          Experience is truly the best teacher.
                          Backup! Backup! Backup! Ghost Rocks!
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Actually mine was a Bestec 300-12Z turns out. I replaced it with a 250W LiteOn because I figured I didn't need 300W in a simple dual core. No bulging caps in my Bestec, but that's because a while back I replaced the bulging capacitor in it. It's a pity that they used such junk caps in the PSUs because they're not so bad as long as the caps haven't died.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Good Japanese Lytics are good for the life of the board too.
                              Those 'new' caps are called Solid Polymer and they aren't even close to being new.
                              I have a retired Intel PII sever board from 1998 that is 100% solid polymer.
                              What has changed is that in 1998 Solid Polymer caps were probably around $15-$20 each.
                              That board's MSRP was $899 in it's day.
                              [If ever] you aren't likely to see a 100% polymer ATX PSU for another 5 to 10 years.
                              There are some caps in PSU's [namely the primaries] that Polymer technology can't even touch yet.
                              I did see a partial poly atx PSU somewhere or other but the price was so ridiculous I didn't care to commit it to memory.
                              - Dr Seuss
                              • omega
                                Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                by omega
                                Hello all,
                                as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                02-09-2024, 03:34 PM
                                HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                09-06-2024, 11:39 AM
                              • harp
                                Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                by harp
                                I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                What is general difference between this products, and what be most useful...
                                01-04-2024, 02:44 PM
                              • Fireballcz
                                Windows 2016 server L2TP/IPsec VPN - two subnets
                                by Fireballcz
                                Hello, please how to properly configure VPN in this environment?
                                I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                I have no problems with VPN connection...
                                07-29-2022, 03:20 AM
                              • SluggerB
                                Tivo HD will not transfer files ....
                                by SluggerB
                                Not sure where to post this, thought this might be the best place
                                Tivo setup:
                                Tivo 1 - Tivo HD, Monthly service (ancient, over 10 years old)
                                Tivo 2 - Tivo HD, Monthly service (ancient, over 10 years old)
                                Tivo 3 - Tivo HD XL, eBay Tivo with Lifetime service (newer but still old)
                                Yes I am the idiot that paid monthly for all these years. I found a broken Tivo HD XL with lifetime service on eBay for $40 (Tivo 3), I bought it, it was a bad power supply, I re-capped it, good as new. So the plan was to cancel Tivo 1 and use Tivo 3 in it's stead. So I...
                                07-02-2022, 08:09 AM
