I wish they made desktop motherboards using laptop sockets.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    If a motherboard manufacturer would do it, I would love to buy such a board, even if its for a platform several years old.
    Yeah I know it sounds crazy, but think of it...
    There are a plethora of cheap cheap cheap used laptop CPU's floating around out there, most of which will more than likely never find a home, cause lets face it... laptop CPUs are for the most part a one shot affair. When a laptop dies or is upgraded, the CPU might as well be orphaned even if it is still good.
    Basically take one of those CPU's, couple it with a nice graphics card, and you would have a nice quiet energy efficient HTPC rig for peanuts... provided they could keep the cost of the board down.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: I wish they made desktop motherboards using laptop sockets.
    They do.
    I have several like that.
    There is also a CPU called a Sossaman which is branded as a Xeon but it's really just a laptop C2D core that is enabled for dual CPU configurations.
    Mann-Made Global Warming.
    - Dr Seuss
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      they did... they are a bit rare.
      what really was cool was the ASUS adapter that allowed one to use a pentium M cpu in s478 mobo... wish I had one of those...
      sigpic
      (Insert witty quote here)
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        right now there is only PGA 998, and its a newer socket, and the processors are more expensive.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Still make them.
          Not rare.
          The more current the CPUs it takes the more it will cost, up to like $350.
          The Pentium-M versions show up all the time and are sometimes cheap.
          [Picked up two of those last month for ~$35.]
          C2D versions run a little more but not too bad.
          There's a guy on ebay that's been trying to unload a bunch of Asus/HP OEM models for over a year and he's asking under $17.99 before shipping.
          http://www.ebay.com/dsc/i.html?_nkw=...LH_TitleDesc=1
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            If you want full sized boards [vice mini-itx] then Jetway, Asus, MSI, AOpen, Itox and DFI make most of them.
            Primarily AOpen and Itox.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              No, socket 479 are quite common.
              They can be either Pentium-M or C2D depending on the chipset.
              The i945 chipset can do C2D in socket 479.
              http://www.ebay.com/itm/370554731743
              [Sorry, had to buy it before someone found it. Now I have 3.]
              http://www.ebay.com/itm/360358907667
              [That ad has been on eBay for around 2 years - Since I lived at my last house. He started with more than 10. He only has one left. For a while there was a second seller listing them. I bought 3 NIB. This one and the one I just mentioned above have a discrete chrontel chip onboard with yipper out so hardware HDTV encoding with no DRM and no video card is needed. On the full ATX version the PCI-E 1x slot was a mistake. It works but it's in the wrong place so you'd have be creative to use it.]
              http://www.ebay.com/itm/360348678944
              http://www.ebay.com/itm/320426181832
              [Those show up fairly often. I don't like SIS.]
              http://www.ebay.com/itm/360409363322
              http://www.ebay.com/itm/400083424038
              [C2D - skt 479 but overpriced IMHO. Been there a long time too.]
              http://www.ebay.com/itm/170402656981
              [C2D and been listed for at least 6 months. Is a mini-board though.]
              http://www.ebay.com/itm/250721210131
              [That one is crap but it's been there for months.]
              http://www.ebay.com/itm/280566159797
              [Have $$$ can go with a Tyan. Been listed forever.]
              http://www.ebay.com/itm/160656029449
              [One of the industrial mobo brands. Almost always a few of those. I got one that takes C2D w/PCI-E x16 + PCI-E x1 + PCI for $9 because the seller didn't know the make/model or specs and that scared the competition off.]
              http://www.ebay.com/itm/140502692093
              [Been there for around 2 years. I know because around 2 years ago I bought one from the same ad. Has dual gigabit lan. Makes a nice low power managed bridge.]
              See, not hard to find at all.
              Most of those have been listed for months and a few for over a year.
              Just have to know what to look for.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                And an afterthought tip for Pentium-M boards/chips.
                Unless you can't get around it for some reason, don't go for the 400FSB only mobos.
                The P-M 2Ghz@/400FSB typically costs 3x or more than what the 2Ghz@/533FSB does.
                If you're patient the 2Ghz@/533FSB P-M can be had for under $10.
                . Which means you can spend more for a better board and hit the same overall build cost.
                - Dr Seuss
                • mockingbird
                  • Dec 2008
                  • 5484
                  Laptop processors are designed to run at high speeds with less power... If desktop boards came out with laptop CPU sockets, it would cut into desktop CPU sales heavily...
                  Laptop Core2 chips run for $10-20... You can get T7xx CPUs for next to nothing, and even the 1066 P8xx CPUs run very cheap.
                  Who wouldn't prefer a laptop CPU with a much higher potential for overlock, or even much lower power consumption than a desktop CPU at normal speed?
                  I've never seen a Socket P or Socket G desktop motherboard.
                  • Evil Lurker
                    Warranty Voider
                    • Feb 2011
                    • 454
                    Your right about T7xx series CPUs being ass cheap. Like a T7300 for $15 cheap. That is a 4 meg cache, 2.0ghz, 800mhz FSB CPU. And it runs at 35W. Tack on $30ish for one of those Calcite motherboards and another $20 for a few gigs of RAM and one would have the basis for a fairly decent HTPC box. Couple it with say a Radeon 5570 and it would be good to go for $100.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Your right about T7xx series CPUs being ass cheap. Like a T7300 for $15 cheap. That is a 4 meg cache, 2.0ghz, 800mhz FSB CPU. And it runs at 35W. Tack on $30ish for one of those motherboards and another $20 for a few gigs of RAM and one would have the basis for a fairly decent HTPC box. Couple it with say a Radeon 5570 and it would be good to go for $100.
                      The Calcite boards I linked to are 533/667 FSB.
                      I think the T7xx is for the wrong socket too but I don't have interchangeability for all of the laptop sockets straight yet.
                      Here's the specs.
                      http://h20000.www2.hp.com/bizsupport...ctID=c00783647
                      It says: "Maximum HP/Compaq approved memory is 2 GB". - Note: "approved".
                      The chipset can do 4GB as long as HP/Asus didn't lock it out in the BIOS or something.
                      - Dr Seuss
                        HP Slim Desktop S01-af1132a Slim Desktop i3-10100 Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-af1132a can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-af1132a boardview and Slim Desktop S01-af1132a schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-12-2024, 03:28 PM
                        HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        HP Slim Desktop S01-aF0011ns Slim Desktop J4005 Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-aF0011ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0011ns boardview and Slim Desktop S01-aF0011ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        HP Slim Desktop S01-aF0009nf Slim Desktop J5005 Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-aF0009nf can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0009nf boardview and Slim Desktop S01-aF0009nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        HP Slim Desktop S01-aF0017ns Slim Desktop S01 3250U Specification for Upgrade or Repair
                        This specification for the HP Slim Desktop S01-aF0017ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0017ns boardview and Slim Desktop S01-aF0017ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
