Best (free) PC performance testing program/software?
    I recently purchased a used HP Workstation with the intention of installing some major upgrades. Today I picked up 2x CPUs and a brand new graphics card. These are all superior to the ones already installed so I want to carry out a before-and-after performance test/benchmark with the machine as it is now and then after each item is installed.
    So I want a good, free program that will help me do these tests, preferably one that somebody has used themselves recently.
    System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
    Re: Best (free) PC performance testing program/software?
    Check out http://www.techsupportalert.com/
    Best freeware for most everything there.
      http://www.techarp.com/showarticle.aspx?artno=520
      It's a script that uses a video encoder to convert a smallish video to h264 high definition - x264 is highly multithreaded and generally uses the processor to the max and the speed also varies a bit with the memory speed so it's a good reference.
      (requries windows and avisynth installed)
      SiSoftSandra is used by lots of websites to test cpu/gpu/memory etc
      http://www.sisoftware.net/?d=&f=downandbuy&l=en&a=
      The lite version is free for personal use only/educational and contains plenty of benchmarks.
      For the first time you'll get a couple of screens where it asks you to agree to download results from others and share your results with others (so that requires an account) ,,, you can uncheck the boxes or do what they say.
      When you actually select a benchmark you have to click on the reload icon at the bottom to actually start the benchmark.
      I'm saying all this because it can be a bit confusing but it's a very good application, worth trying.
      (also note some tests can freeze the system for minutes so don't panic)
      Passmark PerformanceTest is also a good suite to test processor, memory, everything you want: http://www.passmark.com/products/pt.htm
      You can compare the processor marks with the ones on http://cpubenchmark.net/cpu_list.php
      free for 30 days, 24 dollars after.
        I've installed SiSoft and used it a few times now and it's pretty easy to use so I'm probably gona stick with it but also give the others a try too.
        Thanks for the input.
          Depending on the hardware you have, download one of the 3Dmark versions. If it's older hardware give 3dmark06 a run.
          If the hardware is new and DirectX 11 capable, then try 3Dmark11.
          http://www.futuremark.com/benchmarks/
          Don't Bin It - Repair It.
            Cheers. The hardware is in my sig, gota check the DirectX capabilities...
