dell optiplex gx620 won't boot
  • coolcurrent
    • Oct 2010
    • 98
    My dell optiplex gx620 won't boot up, but it displays the initial boot screen, so i entered setup and notice that it won't detect the hardrive and cdrom, but it detects the floppy disk.
    There is power in the cdrom, as it opens and closes when i press the buttons. the hard dist also display a small light under it when i open the casing, and it spins up. i also tried another cd rom and hard driev to be sure the original ones are not bad
    I don't know what is wrong, i have tried all settings possible. could this be a bad bios?
    thanks
  • brethin
    • Dec 2008
    • 1907
    Re: dell optiplex gx620 won't boot
    Was this working and just stopped or are you trying to build setup this board/system. Because to me it sounds like you are building/setting it up and do not know how to enable the drives/ports in the bios.
    • coolcurrent
      • Oct 2010
      • 98
      The PSU got fried, and i replaced. After i replaces, every other thing worked fine except the problem am experiencing today
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        First reset the BIOS.
        Then see if it will boot to the BIOS with all the drives disconnected.
        Mann-Made Global Warming.
        - Dr Seuss
        • coolcurrent
          • Oct 2010
          • 98
          I have reset the bios by removing the battering, but nothing happens.
          Do i need to flash it ?
          if yes, please give me guide as i don't know where to start
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Did you have the power supply de-energized [not just system off] when you pulled the battery?
            Need to pull the plug or have switch on back of PSU set to off while the battery is out.
            If not the CMOS is still powered while the battery is out.
            Disconnect the drives from power, not just the data lines.
            That is a checking for a drive that is bad on the power side.
            You also might try disconnecting the front USB ports along with the drives.
            Occasionally a shorted USB port will much things up.
            Also pull any add-in cards you don't need to see the BIOS screen.
            If still can't get to the BIOS screen you know the problem is in what is still connected.
            Namely the mobo or the PSU.
            The following is just a list of places to go from there:
            A corrupt BIOS is one possible problem and flashing it to a fresh copy would fix it if that's it.
            If you want to go that route then dig around in here to find the BIOS and instructions.
            http://support.dell.com/support/down...emID=PLX_GX620
            Ask if anything isn't clear.
            The GX620's sometimes have issues with caps including the small 4 & 5 mm caps.
            The small ones can manage to dry out without much if any bloating.
            If you have the 85C small caps that's even more of a possibility.
            You may also have a blown chipset so a -good- visual inspection about not is a good idea. You have to remove chipset heatsinks to do that. Look for cracks, pits, shinny spots or any indication of arcing or melting inside the chip. You can't say it's good if you don't see anything but you can say it's bad if you do.
            Some photos showing what you have for caps would help about now.
            - Dr Seuss
            • coolcurrent
              • Oct 2010
              • 98
              Thanks for replying,
              yes i did, i pulled the plug, for some minutes
              i did also remove all connected internal and external hardware too.
              i will do some test/checks and get back to you
              thanks
                DELL OptiPlex 3080 OptiPlex 3000 i5-10500T Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                09-12-2024, 02:30 PM
              • mpower1226
                Dell optiplex 7090 boot problem
                by mpower1226
                Hi masters, need your help in solving this mystery.
                i have a dell optiplex 7090 micro that i bought from local kijiji.
                when i turn it on, error comes out saying no hard disk.
                i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
                i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
                it seems as if the computer doesnt recognize the ssd...
                01-22-2024, 10:37 PM
                DELL OptiPlex 3040m OptiPlex i5-6400T Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 3040m can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3040m boardview and OptiPlex 3040m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                09-12-2024, 03:44 PM
                DELL OptiPlex 7080 OptiPlex 7000 i5-10500T Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 7080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7080 boardview and OptiPlex 7080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                DELL OptiPlex 5060 OptiPlex 5000 i5-8500 Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 5060 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5060 boardview and OptiPlex 5060 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
