Very strange problem with front panel usb ports
  • ipman
    • Jul 2011
    • 159
    Re: Very strange problem with front panel usb ports
    Not really. Strip the wire, solder toghether and wrap it with tape. Should work fine.
    Or cut, fit shring tubing and solder back.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      careful... if you want usb2.0 you can't do that. you have to shield the two sets of data wires from each other. normally this is accomplished with a braided tube of ground wire right under the outermost insulation. what you describes involves breaking not one but both shields... do that and one data pair will interfere with the other pair and vise versa... with usb 1.1 ribbon cables with the pairs non-twisted and intermingled, this was not an issue, but 2.0 is much more sensitive to interference. ever notice that most modern cases use one cable per port even if there are 2 per plug? maybe you see why.
      sigpic
      (Insert witty quote here)
      • ipman
        • Jul 2011
        • 159
        The cut should leave minimal shield loss, as allways should do with shielded cables.
        A few milimeters of shield loss is not catastrophic, provided that you still connect the shield across the cut.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          the other thing to consider is that usb is a fused direct link to the 5v rail of the PSU. they are connected by default. apparently a connection at the end of the line is necessary since it is obviously more than just a connected or not connected issue.
          sigpic
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            There is no shield or plastic covering the cables of the USB ports of the cases that don't work with that motherboard:
            https://www.badcaps.net/forum/showpo...8&postcount=16
              Lenovo ThinkPad P53 Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P53 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P53 boardview and P53 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
              09-06-2024, 09:45 AM
