notebook psu disassembly
  • panegiricus
    • Oct 2010
    • 28
    Hi people , i need help to disassembly this
    http://www.battery-online.org/images...-1650-02-2.jpg
    because the cable is heavy degraded exactly at the psu side, then i need to open it to new solders for the cable.
    I know it's made for no disassembly, i ask you what do you think i can disassembly it (a little saw, or a red-hot blade ? ) for doing a good job.
    A new one its too much expensive for the problem i've with it.
    Thanx.
  • yyonline
    • Jul 2009
    • 692
    Re: notebook psu disassembly
    I usually freeze them, which makes the glue brittle. Then I pry along the seam to crack it open. I'm usually able to get them open, but it's not pretty afterward.
    In what country are you located? What's the part number for the power adapter and what model computer is it for? I can check some places I often get these things from to see if they have that particular power adapter.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      if it's a LiteOn PA-1650-02 as in the image URL, it's a 19V 3.42A (65W) Laptop PSU.
      available like sand on the beach.. (and if not, look for 19V 4.74A (90W) PSUs)
      connector is 5.5mm x 1.7mm
      • NxB
        • Feb 2009
        • 1595
        Hit it on the side with a rubber mallet. The glue will crack and the unit comes apart with relatively little damage. I'll try freezing before hitting it next time, that sounds like it completes the puzzle.
        • bp1
          • Jul 2010
          • 46
          Same here. Freeze it. Hit the seam with a hammer and eventually the unit comes apart.
          When work is complete glue it backtogether
          • Krankshaft
            • Jan 2007
            • 2328
            Get a block plane blade refill put it on the seam and whack it with a hammer. The blade will act as a wedge and pry it apart.
            Consult this thread for the picture of what I'm talking about:
            https://www.badcaps.net/forum/showthread.php?t=13586
            While the freezing method may work on cheaper supplies where the manufacturer used less adhesive I've come across some really well glued ones where it took quite a bit of hammering with the blade to open them up.
            This is the second post this month asking the same question the search function is your friend .
              HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-07-2024, 07:12 AM
              09-07-2024, 06:40 AM
              HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
              09-07-2024, 05:50 AM
              HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
              This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
