Successful P4 478 OEM Gateway to retail Intel bios flash...
  • joe67
    • Mar 2012
    Re: Successful P4 478 OEM Gateway to retail Intel bios flash...
    Originally posted by Evil Lurker
    Got bored last night. Decided to try and kill my OEM Gateway D865GLC motherboard.
    I been tryin to flash the damn thing to the retail Intel bios for weeks without success until last night.
    As you know, Intel's flash utility checks the BIOS strings for manufacturer ID, and if they don't match, you don't flash, even if you attempt it in recovery mode.
    So just for craps and giggles I took the latest Intel BIOS and put it on a floppy disk and renamed it to the current installed Gateway bios .BIO file. Then I set the jumper to maintenance mode and set the BIOS to scan for user bins. Then I took an old no-name PCI NIC and slapped my old KX7-333R motherboard BIOS in the boot rom socket and slapped it in my puter with the logic that well maybe I can confuse it.
    Well after removing the jumper so it would flash directly from a floppy in recovery mode, lo and behold the thing actually flashed to the retail BIOS! The icky-poo 15A vendor identifier is gone and replaced with a lovely 86A.
    Gateway can officially kiss my
    AFAIK, I am the only person to have achieved this method on this particular chipset without editing the bios strings.
    I now have all the hidden settings that normally ship with the retail board enabled! While not useful for overclocking, at least I can set my AGP aperture and memory timings so it does not default to the crappy 320mhz whenever I put double sided DIMMS in it.
    Everything seems stable and runs fairly decent. I did have to phone into Micro$oft though because my LAN drivers had to be installed before I could get on the net.
    However there are two quirks that I just don't get... first the CPU fan runs wide open and second the little red LED light that normally flashes when there is trouble is now constantly lit. BIOS error log is clean, and CPUID pulls up the correct info on all the components.
    Also, on another note, I found the cheapest P4 heatsinks ever. Turns out the DELL poweredge 6 heatpipe tower coolers will fit in the OEM Gateway "swing bar" retention bracket. Cheapest I have seen is around $7 including shipping... they are MASSIVE. I'm thinkin that with one of these puppies installed I could possibly keep my Prescott in spec with nothing more than the case fan blowing over it.
    Thanks a lot for your procedure. It worked for me!!!
    I have a Intel 875pbz motherboard that had the 015A identifier with the P13 version of the Gateway bios.
    I downloaded version P14 (086A identifier) .bio file from Intel and placed it alone in a freshly formatted floppy disk and renamed the .bio file to match the Gateway .bio P13 file name (from its website).
    The key of my success was to go into the bios in maintenance mode (set jumper on two upper pins) and set the option "scan for user bins" to Enabled. Then, I removed the jumper to set it in recovery mode, loaded the floppy and restarted. The screen was blank, the floppy disk was working and after several beeps (5 minutes or so) the computer shut down on its own. I put the jumper back on normal mode (two lower pins), removed the floppy and reboot the computer and tada... Intel Factory bios was flashed with 086A, P14. I then was able to flash the latest version (P34) via Windows without any problems. Now I am able to see a lot of more options on the bios including the AGP apperture memory (up to 256 mb). The Gateway splash screen is gone and now it shows the Intel one.
    I do, however, have the same results as you. The CPU fan now runs constantly at ~3000 RPM (Gateway Bios was controlled depending on temperature) and also the DIAG led stays lit in red. I cannot find any errors in the bios log and everything works ok. Were you ever able to solve this condition?
    Thanks again.
    • JSD
      • Mar 2012
      • Vermont
      Originally posted by mahkeymike
      Cant seem to let this mobo R.I.P Was able to see and decompress contents with AMIdeco but now cant figure out what file is OEM logo.
      If you look you will see "OEM LOGO data" but this file when extracted is 1KB in size.
      Were you ever successful in chaning to LOGO?
      I have an old Pentium III gateway motherboard that I always wanted to change the logo for.
      Any updates or info on what to do?
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
      • abhorsen
        Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
        by abhorsen
        Hey guys,
        Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
        Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
        Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
        07-06-2023, 10:22 AM
      • mrrubik
        Dell Optiplex 7010 micro bad BIOS flash?
        by mrrubik
        Hi folks,
        I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
        After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
        Steps I took:
        1. Read BIOS with CH341a, verified hash twice
        2. Patched
        12-23-2024, 04:11 PM
      • AkaBukai
        Is it okay to flash stock bios onto the motherboard's BIOS?
        by AkaBukai
        Hi there,
        I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
        The little LED on the power button is flashing slowly and nothing happen.
        This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
        So I decided to flash the BIOS using a cheap programmer.
        And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
        I also...
        12-19-2024, 12:15 PM
      • James Jackson
        Panasonic CF-20G0247VM BIOS Bad Flash Help
        by James Jackson
        I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
        Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
        05-01-2025, 11:28 AM
