No Safe Mode
  • ChrisMohrSr
    • Jan 2011
    No Safe Mode
    I would like someone on the forum to help me with two problems.
    At the present time I am using a Dell Vostro 200 computer with the Windows XP Professional version.
    Problem One: In the past I would sometimes solve a problem with the computer by going into Safe Mode and then doing a System Restore. The other day while using an Aspire AST135 computer it became unresponsive so I decided to go to Safe Mode and do a System Restore. I got as far as choosing the system to restore (there was only Windows XP), but when I hit Enter the screen became a light dark and nothing would function. I say "light dark" because when the system is running properly the black screen is a deeper black than when the system completely gives up, as it does in this case. This has happened to me before on the computer I am now using to write this. I had to call in a technician to get the system back.
    My question is: Why does this happen? What could cause the system to completely die when I try to go into Safe Mode? When it happened on this Dell Vostro 200 computer I thought it was probably a glitch in the machine, but now it has happened to the Acer computer. And I do not relish the thought of spending a hundred or more dollars to have it rectified. Is there anything I can do to fix the problem myself?
    Problem Two: I am now using this Dell computer, but the image will not adjust to my widescreen monitor. It displays a standard 3 to 4 image stretched out to fit the wide screen. How can I correct this?
    I am greatly indebted to anyone who can help me solve my problems.
    Christopher R. Mohr Sr.
  • seanc
    • Nov 2008
    • 1319
    Re: No Safe Mode
    Regarding problem 2, if you're using a lesser known brand of widescreen monitor and Intel's onboard graphics, you'll need to download a particular set of drivers.
    http://www.intel.com/support/graphics/sb/CS-028366.htm
    Regarding the issues with Safe Mode, anything can cause it. What's the problem with starting up in normal mode?
    • yyonline
      • Jul 2009
      • 692
      Re: No Safe Mode
      I'd recommend downloading the correct video driver directly from Dell. Dell often tweaks the drivers for their specific hardware. To get the driver, goto support.dell.com, download drivers, and enter the service tag number of the computer.
      Finally, if the monitor is connected with VGA instead of DVI, you may need to adjust the resolution manually in the display control panel. DVI will automatically adjust the resolution almost always. VGA will sometimes, but not others.
      • ChrisMohrSr
        • Jan 2011
        Re: No Safe Mode
        I have solved the number two problem of the stretched display by installing a missing driver, but my number one problem remains. The computer will not boot. I tap F8 and bring up the screen with all the different choices. That's where the problem comes in. No entry on that screen will respond. That is the problem. I have used that screen in the past with complete success, but now nothing on that screen will respond.
        • seanc
          • Nov 2008
          • 1319
          Re: No Safe Mode
          Are you using a USB keyboard? Have you checked to see that USB keyboard support is enabled in the BIOS?
          • ChrisMohrSr
            • Jan 2011
            Re: No Safe Mode
            I was using the same keyboard that I used when I used that screen before to go into Safe Mode. Nothing changed except that screen just stopped responding.
            • steve2
              • Dec 2010
              • 121
              Re: No Safe Mode
              Have had this on 3 computers in last year. Something corrupts the mbr file and will not boot to the operating system. Easier to provide a link than to try to explain. The computer will post , you can get into bios, but after the splash, screen goes black (but iis still on as the monitor doesn't say lost signal).. When trying to boot in safe mode (if it lets you get that far, will usually show a loading screen that stops(all black screen with white letters showing whats loading) at a file. The link here has fixed this , but some malware that is designed to just corrupt the mbr (master Boot Record) file. http://askbobrankin.com/fix_mbr.html
              • grimacelord
                PS5 | CFI-1215A | EDM-030 | Stuck In Safe Mode 99% Processing
                by grimacelord
                I have a CFI-1215A PS5 (EDM-030 board) here that won't boot normally. It currently will immediately boot into Safe Mode upon power button press with a screen that says "Processing" and then a progress bar that usually begins around 75-84% and slowly climbs up to 99% where it will hang forever. The console will not ever escape past the 99% mark.
                Things I have tried:
                1. Tried force booting into Safe Mode by pressing and holding power button for 2 beeps so I could use a reinstallation USB, but the console still boots into Safe Mode with the...
                03-27-2025, 12:09 PM
              • lab10.haifa
                Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
                by lab10.haifa
                Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
                It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
                There is no damage on the motherboard. No short circuits.
                Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
                Thanks....
                10-08-2025, 02:55 AM
              • duwane
                KB and Trackpad only work in safe mode - 820-4924-A Macbook Pro Late 2015 A1502
                by duwane
                Hi all. I hope someone has come across something similar, as I am baffled.
                I have a faulty logic board from a 2015 A1502 Macbook Pro Retina (820-4924-A). Some signs of liquid, but all corrosion cleaned, and several components refloated or replaced to eliminate any visually corroded areas of the board.
                Machine boots fine now, but the keyboard and trackpad do not work at all when booting normally into Catalina, Big Sur, or Monterey. At the login screen, the cursor does not move at all when moving on the trackpad, and no keys on the keyboard respond on screen, however...
                04-11-2022, 08:49 PM
              • DynaxSC
                Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
                by DynaxSC
                I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
                I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
                Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
                Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
                05-04-2025, 12:08 PM
              • Meraxes
                PS4 Pro stuck in safe mode
                by Meraxes
                I have a Ps4 Pro and it got stuck in safe mode, when I turn on the console, the LED is white, it goes into safe mode and after copying the update, the console shuts down, but normally it had to restart and continue the installation, I also changed the hdd and usb flash drive and it does the same, can anyone help me with any suggestions?
                04-22-2023, 12:24 PM
