Dell Optiplex GX150, CDROM issue
  • Maxxarcade
    • Jul 2006
    • 973
    Is the GX150 really picky about the type of CD/DVD drive that is used? I can't get it to recognize two different DVD readers. They show up as Unknown Device in the BIOS, and it keeps saying Secondary Master Disk Not Found.
    I've already updated the BIOS to A11. Strange that this system would do this. I've used DVD drives on much older systems without a problem.
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Dell Optiplex GX150, CDROM issue
    Darn, I posted in the wrong section... Sorry, been a long time :-)
    • yyonline
      • Jul 2009
      • 692
      Check your cables and jumper settings. If you're using a 40 conductor IDE cable, not all of them work with cable select. Try an 80 conductor IDE cable or setting master with the jumper.
      It's not uncommon for older Dells to mis-report a device in the bios, but it should work, even if the bios isn't sure what it is. I usually see DVD+RW drives reported as "CD-ROM" in older Dell bioses.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Thread moved to "general computer discussion"
        Is this a standard IDE drive, or a small formfactor laptop-style drive?
        Ludicrous gibs!
        • Maxxarcade
          • Jul 2006
          • 973
          It's a standard IDE drive. I've already tried different jumper settings, and the ribbon cable looks OK. I'm going to bring an old CDROM drive home from work tomorrow and try that.
          Figures, all the years I had a box of CDROM's laying around collecting dust, and I get rid of them 2 days before I pick up a computer that needs one
          I got this system out of the trash last week. Only reason I even bother fixing it, is because it has a Windows 2000 COA still on it, and I want to tinker with it. Also got two other Dells with WinXP Pro COA's. Already fixed the GX270 (3.2Ghz P4) up real nice, but the Precision 340 isn't worth buying RDRAM for.
          • toastygoodness
            • Jul 2005
            • 813
            i would just try another ribbon cable just in case... otherwise u can try switching ide ports since it should be old enough to have two.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              geeks.com has samsung pc800 rambus 256mb ECC modules for $8.50 a pop right now... not sure if that helps, but i thought you might want to know.
              http://www.geeks.com/details.asp?inv...-SAM-R&cpc=SCH
              sigpic
              (Insert witty quote here)
              • Maxxarcade
                • Jul 2006
                • 973
                Got it working. Just had to re-seat the ribbon cable at the motherboard end. Also found a Lite-On CDRW drive that matches the case perfectly. Installing Win2k Pro as we speak.
                The noisy Maxtor HDD is driving me nuts though. I hate that high pitch metallic whine.
                • yyonline
                  • Jul 2009
                  • 692
                  Old bearings. Nothing you can really do aside from swap the HD. If you do decide to replace it, be aware that a lot of the older Dell bioses do not properly support 48-bit LBA, limiting your largest replacement drive to 137GB. Larger drives appear to work initially - until one day the boot sector or file system index is overwritten without warning.
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    I probably won't be messing with it much, so I'll leave the existing drive alone. My Win2k CD didn't work with the COA, so it's on the bottom of the priority list now.
                    • yyonline
                      • Jul 2009
                      • 692
                      In order for the Dell CD key to work, you need an OEM Windows 2000 CD. A retail Windows 2000 CD uses different keys and will not work. Any Dell pressed Windows 2000 CD will install without a key (uses a bios check).
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        I figured that was the case. Time to search for another CD.
                        • TheLaw
                          • Jan 2011
                          • 477
                          I have a GX150 and I put a DVD drive in it a while ago. It was some cheap generic NEC drive and it had no problems with it.
                          Hmmm....maybe see if your IDE configuration is messed up in the BIOS?
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            ...but the Precision 340 isn't worth buying RDRAM for.
                            If anyone is looking for RAMBUS, I have 2gb of it sitting here in 512mb sticks......
                            <--- Badcaps.net Founder
                            Badcaps.net Services:
                            Motherboard Repair Services
                            http://folding.stanford.edu/
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              if the OP has no interest i might be. I have a rambus p4 board with 4 slots...
                              sigpic
                              • TheLaw
                                • Jan 2011
                                • 477
                                =OOOOOOOOOOOO. God, I'd need a mortgage to buy 2GB of RDRAM. A 128MB stick cost me like $85...in 2006. Wow, if you sold that to some silly person on eBay....you easily have $1K USD.
                                • dood
                                  Deputy dood
                                  • Mar 2004
                                  • 2462
                                  An auction just ended for 2x512mb and 2 terminators... Opening bid was 49.99 and nobody bit... BIN was only 59.99
                                  Ludicrous gibs!
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    wow... i guess 256mb ecc pc800 for $8.50 a shot is a bargain?
                                    sigpic
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      It's not bad... as long as you have 4 slots and don't want more than 1gb of RAM. If prices were that low last year, I probably wouldn't have thrown out some of the machines that I did. They got chucked based solely on the fact that they ran RDRAM.
                                      Those 512's on eBay aren't a bad price, either... Hell, DDR is creeping up into that range (albeit new)
                                      Ludicrous gibs!
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        You can make your own OEM CD from a Retail CD - at least that's what I read on the internets a few days ago (I ran into a bunch of laptops with Windows 2000 OEM stickers and wanted to get Win 2k installed on them so I'm working on this issue as well).
                                        From what I read so far, basically all you have to do is make/find an image of Windows 2000 (doesn't matter which version), then edit the file "SETUPP.INI" in the "i386" folder - particularly the last 3 digits of the PID value. What those last 3 digits mean:
                                        000 - Retail CD keys
                                        OEM - OEM CD keys
                                        270 - Volume License CD Keys
                                        I have an ISO image but haven't found a good ISO editor. I can unpack the ISO and change that ini file, but then I can't get the CD to be bootable any more. Will let you know if I work out something.
                                          DELL OptiPlex 3080 OptiPlex 3000 i5-10500T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 02:30 PM
                                          DELL OptiPlex 7080 OptiPlex 7000 i5-10500T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 7080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7080 boardview and OptiPlex 7080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL OptiPlex 3070 OptiPlex 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3070 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3070 boardview and OptiPlex 3070 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL OptiPlex 3080 OptiPlex 3000 i5-10500 Specification for Upgrade or Repair
