How not to build a PC
  • c_hegge
    • Sep 2009
    • 5219
    1. Don't put a P4 Prescott CPU in an SFF case
    2. Don't leave cables loose, especially with IDE cables
    3. If possible, use a case fan or 2
    4. NEVER do all of the above. As I type this, there's a little PC sitting next to me which I'm stress testing. It is a P4 Prescott 3.0GHz, with an Antec NSK1380 case, NO case fans whatsoever, and the cables are all in a birds nest. The outside of the case is currently too hot to touch and the CPU is hitting 85°C with the fan at max speed (3200RPM).
    I actually put this together. It's my new way of stress testing re-capped motherboards. Not only do I hammer the CPU for a few days, but I now do it in an SFF case with no ventilation
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: How not to build a PC
    That poor little processor. I almost feel sorry for it. Well, almost.
    A man convinced against his will is of the same opinion still.
    • bigbeark
      • Jan 2010
      • 661
      Pity the nearby components. Prescotts seem to thrive on their own heat!
      Too bad they end up pan-frying Northbridge chips and any caps silly enough to get near them.
      • Wizard
        • Mar 2008
        • 2296
        Check your Prescott CPU thermal throttling. There should be a utility out there that will tell you if this thermal throttling is happening.
        Cheers, Wizard
        • acstech
          GrumpyModerator
          • Jul 2007
          • 1432
          I think there's a term for that...
          http://en.wikipedia.org/wiki/Nuclear_meltdown
          That said, these are good suggestions. I generally consider it a problem when I see processor temperature go above about 60c, since I know things are only going to get worse when in the hands of the customer. Heatsinks fill up with dust, fans fail etc.
          What program are you using to stress the processor? May I suggest Intel Burn Test?
          http://majorgeeks.com/IntelBurnTest_d5987.html
          • c_hegge
            • Sep 2009
            • 5219
            It will only be there for the stress testing. Once that's over it will get put in a standard case with some better ventilation.
            To stress the CPU, I use prime95.
            • bgavin
              • Jan 2007
              • 1355
              This is about the same as stress testing an egg on a railroad track.
              The egg isn't much good after the test.
              Why do you expose your gear to such detrimental conditions?
              Do you think the processor 'heals itself' after coming back down from severe temps?
              If you want to stress test your hardware, give it optimum running conditions (read: cooling) and drive it to maximum performance. Prime95, etc will do the job for you.
              • c_hegge
                • Sep 2009
                • 5219
                I don't normally do this. I was just curious this time around to see how it would handle the heat, but it's the first time I've done this and will probably be the last.
                • Spode
                  • Dec 2010
                  • 41
                  I'm sure I remember a particular memory manufacturer stress testing their memory in an oven at extreme temperatures before shipping them out, to make sure that the overclocking was stable.
                  And no, a Prescott CPU never deserves sympathy
                  • TheLaw
                    • Jan 2011
                    • 477
                    I have a 3.06GHz Northwood in a SFF case. I had to buy a copper heatsink and a Delta fan to keep it cool. I kid you not.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I was just using the stock cooler here.
                        ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                        This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 10:50 PM
                        ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                        This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-06-2024, 11:05 AM
                        ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                        This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                        This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 07:07 AM
