Installing a Nvidia GPU in server 2019
  • LA1
    • Jun 2011
    • 23
    • USA USA USA
    well like the title says. I have a windows 2019 server and I am trying to install an Nvidia GTX 1050 Ti.
    I downloaded the exe from NVIDIA
    used 7zip to extract the driver folder
    go to device manager and try to update the grapics card, says something like generic windows graphics
    the driver was a WHQL DRIVER
    It did not work
    oh yeah I tried win 8 and win 10 64 drivers
    EDIT:: NEVER MIND, THE WINDOWS 10 DRIVER WORKED. i WROTE THIS WHILE REBOOTING AFTER INSTALLING WINDOWS UPDATES, THOUGHT I WOULD SAVE TIME.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Installing a Nvidia GPU in server 2019
    Win10 drivers for Server 2016 and newer.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • piernov
      NVidia bumpgate
      by piernov
      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
      May complete this post at a later date with more details.
      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
      03-27-2021, 10:34 AM
    • badboyzzz
      Nvidia Shield 2019 - P2897 power on but no display
      by badboyzzz
      There is a problem with nvidia shield 2019 p2897. The lights of the device are on but there is no voltage in the red marked areas. The green areas are normal and the chip in the yellow area is heating up in long-term voltage. Does anyone have a diagram or an idea? Thanks in advance
      04-11-2025, 08:17 AM
      NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
      The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
      10-02-2024, 08:52 AM
      NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
      The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
      10-01-2024, 01:54 PM
    • osrex
      LED DRIVER KEEPS DYING
      by osrex
      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
      i have no datasheet at all for the LED lights, all i have is its length.
      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
      05-05-2025, 03:36 PM
