radeon 9800 pro help kinda
  • yonu
    • Nov 2007
    • 138
    hey guys I need a second thought on this I have a PC setting here I am working on for a customer that is running windows 7 and had the generic WDDM driver installed for the 9800 pro well they were having playback issues so I went to install the ATI 9800 drivers from ATI.com now as soon as windows loads all that is on the screen is garbage if I bring up the system with vnc the screen is fine in the viewer if i boot to safe mode and uninstall the driver it boots back up fine in normol mode. I am hoping someone here has an idea as I hate telling folks they need new hardware.
    Thanks,
    yonu
  • Quasar
    • Sep 2010
    • 132
    Re: radeon 9800 pro help kinda
    There are no ATI-supplied Windows 7 drivers for your card.
    32 or 64 bit?
    Get to archive section and use older drivers.
    Catalyst 9.1 might be worth a try.
    Suggestion to run the install in compatibility mode.
    Do some Googling on: radeon 9800 windows 7 issues
    http://www.omegadrivers.net/
    Keep an eye on this site. He does a nice package and I've used his stuff on and off for years. My game rig only worked correctly on his drivers.
    Q
    • yonu
      • Nov 2007
      • 138
      Thanks for the help I drivers I had tried before were the vista drivers I had tried the ATI XP driver with no luck. However I tried the Omegadrivers for XP and they worked perfectly Thank you very much for the help
      Thanks,
      yonu
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Omegadrivers rule.
        A working TV? How boring!
          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
          10-01-2024, 12:46 PM
        • YOUCEF4787
          Installation Issue with AMD Radeon 520 Graphics Drivers on Dell inspiron 15 3576
          by YOUCEF4787
          I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
          Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
          Laptop Model: Dell Inspiron 15 3576
          Operating System: Windows 10
          Graphics Card: AMD Radeon 520
          Steps I have taken:
          Downloaded the latest AMD...
          07-08-2023, 05:23 AM
          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
          10-01-2024, 01:07 PM
          AMD Radeon RX 470 / RX 580 Schematic & Board View
          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
          10-01-2024, 12:52 PM
          AMD Radeon R7 340 / R7 430 Schematic & Board View
          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
          10-01-2024, 12:36 PM
