Are these caps bad?
  • Mnight
    • Jul 2010
    Are these caps bad?
    I am hoping someone can tell me whether or not I should have these caps replaced, I have been having random shutdown issues on my pc and after alot of tests I have kind of narrowed it down. These caps were the only ones that looked like they might be going bad, but keep in mind they look worse in the pic here. But for a cap to be good does it need to be completely flat on top or overtime do they always swell a bit? Also Im not sure the brand, I can see TK on the sides of some or ATWY not sure if that helps.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Are these caps bad?
    Caps do not have to swell or be bloated in order to be bad.
    A 1000uF cap can measure 500uF and that is bad because it is out of tolerance. A multimeter with a capacitance test can measure capacitance.
    An cap can have high ESR (ohm) and that can also be bad for a motherboard application. An ESR tester is required to measure ESR.
    --- begin sig file ---
    --- end sig file ---
    • c_hegge
      • Sep 2009
      • 5219
      TK are a bad brand. I recently replaced a few on an ECS/Compaq motherboard. If you are going to re-cap it, replace those solid polymer caps too. Those look like "elite" brand. Sometimes when they fail, they can explode and the can flies off.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
