Abit Recapped KA7-100 Probs
  • Bh420
    • Nov 2003
    • 7
    Sent my KA7-100 board to abit for free cap replacement think it was about a year ago. this morning i was cleaning out all the nice dust bunnies and noticed something... 2 replaced caps are bulging up and one had electrolyte on the top. first one is the cap behind and inbetween PCI1 and PCI2, next one is next to agp slot on PCI1 side it is the one closest to the back fo the board with the keyboard and usb ports etc.. the caps are JPCON or IPCON not sure see attached photo. also see attached images of bad caps..
    anyone else have this problem ??
    Bh
    image of good cap just posted to help identify brand of caps on board:
    2 bad caps i talked about notice bulging tops:
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    That is the prime reason I recommend NOT sending your board to Abit for recapping. They use the same shoddy caps that they used before!! Those nasty caps marked 'JPCON' are even worse than the 'Jackcon' caps also used by Abit (and many other manufacturers also).
    Yeah, it needs to be recapped again! I've got 4 KA7-100's on my bench burning in after being recapped as we speak!! Very common board for bad caps!
    If you plan on recapping it, use a known quality capacitor manufacturer, such as Panasonic, Sanyo, Nichicon, Rubycon, etc... A good vendor is www.digikey.com, although, for small quantity, they are VERY pricey!! I replace 26 caps on the KA7, replacing everything 1500uF and up, also replacing a few of the 1000uF caps.
    Below is a KA7 I've recently recapped. They are tricky to work with, because of the space limitations. The caps around the CPU need to be installed at a slight angle to avoid interfering with the processor. The rest is not too difficult.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Bh420
      • Nov 2003
      • 7
      Just as I figured they did it for free and only cost me $6 to send it to them hehe. How much for a pack of caps from you for replacing them I know how to solder so I shouldnt have any problems. I have got desoldering equipment and a good weller iron.
      Bh
      also how much to send it to you to get them done? just curious its a good board minus the damn cap problems ive got a 950 stuck on it and 2 256mb curcial dimms and it is still a pretty fast machine. not as fast as this XP2700+ but still good for other things
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        My KA7 kit usually runs $24.00 + $4.00 shipping (USA only). Cheaper than Digikey, and no profit shipping... This kit includes 26 replacement caps as follows:
        16 - 1500uF 10v caps
        8 - 2200uF 10v caps
        2 - 1000uF 16v caps
        If you want one, shoot me an email at: admin@badcaps.net.
        Team : 49813
        Join in!!
        Team Stats
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • ziplock
          Abit BE6-II motherboard
          by ziplock
          Greetings,
          I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
          I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
          04-20-2025, 02:09 PM
          ABit IP35 Pro Motherboard Schematic
          ABit IP35 ProABit IP35 Pro Motherboard Schematic
          A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
          10-31-2024, 02:06 PM
        • tbalint3
          Abit ST6-Raid repair
          by tbalint3
          Hello All,
          I am trying to repair an old Abit ST6-R motherboard.
          The symptoms are the following:
          I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
          It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
          If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
          09-01-2024, 10:03 AM
        • N3Star
          Abit IC7 no POST 2nd battle
          by N3Star
          previously I gave up on this MoBo, but here we are again. For starters I'll give a link to previous thread: https://www.badcaps.net/forum/showthread.php?t=95433
          What has changed:
          - I still don't have a PCI GPU, but I have a PCI dignostic board
          - I measured the temperature and drain resistances of these hot MOSFETs:
          (right) 3.3V line: 100Ohms, gets up to ~80C,
          (left) 1.5V line: 430Ohms, gets up to ~65C
          What PC diagnostic says:
          -without GPU: goes through all post codes, keyboard is responsive, after hitting F1 key post codes go all...
          09-24-2022, 03:43 PM
