Bulging GSC 1500uf Caps
  • sandrogalli
    • Aug 2006
    I have a Jetway 650DF that won't post, and on closer inspection some of the caps look in pretty horrible shape.
    There is leakage on most of the GSC 1500uf 6.3V (part numbers T20C and some T20D). They are approx 10x15mm.
    I was wondering what type of capacitor would be best to replace them?
    I found these on ebay and was wondering if they would do the trick:
    1) Panasonic FF 1500uf 6.3V
    2) Rubycon YXG 1500uf 6.3V
    3) Samxon GC 1500uf 6.3V
    Also it'll be my first time replacing caps so if there's anything else i'm missing let me know. Thanks
  • sandrogalli
    • Aug 2006
    Re: Bulging GSC 1500uf Caps
    Does anyone know anything about the GSC T20C's? Whethere they are Low ESR for example, I wouldn't want to replace Low ESR caps with ones that weren't...
    • yyonline
      • Jul 2009
      • 692
      Most motherboard capacitors will be low ESR. Are these 1500uF capacitors all in a row near the cpu? If so, they need to be replaced with "ultra low" ESR caps. That looks like a Pentium 4 motherboard, so for possible replacements:
      https://www.badcaps.net/store/produc...products_id=40
      https://www.badcaps.net/store/produc...products_id=65
      Either of those will work as replacements, assuming the 10mm diameter you stated is correct. Rubycon is generally regarded as one of the most reliable brands out there. Samxon is a bit less expensive, also reliable. Both will outperform the GSC in there, which is one of the least reliable brands.
      Are there other GSC capacitors on the board? Best to replace them all, as it's only a matter of time before they go too. GSC is *that* bad.
      They are sold by the site's owner, so you don't have to worry about getting counterfeits on eBay. I've had mixed luck with eBay...I've gotten some great deals on genuine stuff, but I've also been duped. If you're new to recapping, and don't know how to spot fakes, it's better to stick to trusted sources.
      • sandrogalli
        • Aug 2006
        thanks yy, exactly what i needed to know.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5038
          • New Zealand
          I wouldn't buy capacitors from eBay either. Even if they are genuine, they may be very old.
          Best to buy from Badcaps.net or other good places like Digikey, Mouser, Farnell etc.
          Personally I buy mine from RS-Components\Allied Electronics
          Low ESR is a must for motherboards but there are other factors too. It's best to try and look up the information on the old capacitors and then find replacements which match them as best you can (in specifications, not quality!)
          This may not be possible with GSC specifically as their website appears to be gone.
          Ripple current should meet or exceed the old capacitors, you can buy perfectly good new capacitors but if the circuit design is expecting capacitors which can tolerate higher ripple current than the ones you put in they will not live as long as they should.
          -David VanHorn
          • re-atari
            Denon AVR-X2000 mainboard caps bulging
            by re-atari
            I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
            I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
            09-23-2020, 10:37 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
