Capacitor plague
  • alfredo2j90
    • Oct 2021
    Capacitor plague
    Did the plague or the early 2000s only effect electrolytics of a certain size?
    • 31126
    Re: Capacitor plague
    no
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
    • chth96
      Should I replace polymer capacitor?
      by chth96
      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
      Is this ESR value of polymer capacitor correct?...
      11-18-2022, 04:22 AM
