Capacitor Bungs
  • idiotthomas
    • Mar 2010
    Capacitor Bungs
    Can any one provide specifications and drawings for capacitor bungs including the manufacturing process know how?
    Thx
  • brethin
    • Dec 2008
    • 1907
    Re: Capacitor Bungs
    Why? Do you plan on manufacturing caps? I have never had to replace just a bung on a cap. If the bung is hosed its because the cap is hosed, or it was damaged during a install.
    • Krankshaft
      • Jan 2007
      • 2328
      Re: Capacitor Bungs
      Simple molded rubber nothing very complex about them.
      The good cap manufactures do more than the cheap flat rubber plug or bullyeye pattern though. If you look at a good caps bung you'll see what I mean. This is so during defluxing and board washing the chemicals don't get trapped under the caps.
      • idiotthomas
        • Mar 2010
        Re: Capacitor Bungs
        Actually, yes.
        15million of them per month, if I can strike a deal.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • AleXis6
          Manufacturing Date of Electrolytic capacitor
          by AleXis6
          Guys. could you help me please to decode some codes of main capacitor's producers.
          I would like to know the manufacturing date.
          Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
          If I understood correctly:
          1. Nichicons marks date of production as (see the attached pictures) H2116
          I don't understand the meaning of first letter - may be it is code of factory.
          21 -year
          16 week
          I bought this capacitor recently.
          another one-
          2....
          10-11-2021, 02:20 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
