Illinois "PKSM" capacitor
  • Behemot
    • 4845
    • CZ
    What is this shit I mean it's some kind of general purpose caps, I know that, but why is there NO datasheet or sometin' when it's manufactured 12. week of 2015? That some daaamn custom part again?
    • 21446
    Re: Illinois "PKSM" capacitor
    Any pictures of the offending item
    • Behemot
      • 4845
      • CZ
      Too lazy right now, but these're small D5 mm (5 or 7 tall), 22 uF/50 V, all black, PKSM, 105 °C, 1512 manufacturing date, nothing else.
      It's a little update, they used to use some no-name crap in there (Jiang Hai, Jamicon etc.) 22/50 for 85 °C max, but still, replaced them all just to be sure with Chemi-Cons LEs and KMGs (there are two spots where it does not like LEs). One of them already had 3times the ESR of the rest…and I don't particularly trust IC, especially with this they're showing.
      Haven't them been like bought by CDE? It looks to me they changed almost ALL of their series since I've been going through them couple years back.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        One oddity I noticed, looking through IC's products diagram, is that IC's series names are 3-character, not 4-character. So custom? Counterfeit? Quien sabe?
        PeteS in CA
        • Behemot
          • 4845
          • CZ
          Must be custom than. I took another unit as this one likely has bad CPU or something around the way. This time the one in the usual spot was totally done and couple others were bad too so I'll be replacing them as usually with something I trust.
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            Yesterday, 12:14 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
          • chth96
            by chth96
            06-02-2024, 07:31 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
