Need new caps
  • Nagoshi
    • Nov 2009
    Need new caps
    Nobody replied in my https://www.badcaps.net/forum/showthread.php?p=87951#post87951 but all I really want is what caps should I replace them with.
    The mobo is a DFI LANParty UT nF3 250Gb.
    List of caps:
    - 20 x Nichicon 1000uF 6.3v HM 105C
    - 5 x Chemi-con KZG 1000uF 10V
    - 1 x Chemi-con KZG 470uF 16V
    - 4 x Chemi-con KZG 1500uF 16V
    - 6 x Chemi-con KZG 3300uF 6.3V
    - 18 x Chemi-con KMG 100uF 16V
    - 4 x Chemi-con KMA 100uF 16V
    The two caps that went visibly bad are Nichicons.
    Thinking about re-capping the whole motherboard. What should I get?
    Thanks!
    DFI LanParty UT nF3 250GB [bad caps]
    ML-30 / Mobile 3000+ Claw CG / 3400+ Claw C0
    2x512MB Corsair XMS4404v1.1 TCCD
    6800GT
    Corsair 400CX
    by momaka
    03-12-2025, 03:42 PM
  • laskr1999
    DFI Lanparty NF3 250GB recapping
    by laskr1999
    Hello!
    I have got a DFI Lanparty NF3 250GB motherboard, that have all of the capacitors failed, board still working.
    I have read, that I need to match ESR, Capacitance, Voltage to have a quality recap, but with ESR im in a problem. 0.012 ohm is what i see on the vrm caps specs, but lowest I could find is 0.018 and up, usually 0.04. Can someone help me find good replacements?
    I'm located in EU, and I have found a guy here on the forums who listed the caps, so here are they:
    - 1 x Chemi-con KZG...
    Yesterday, 04:44 PM
  • laskr1999
    DFI Lanparty NF3 250GB complete recap help
    by laskr1999
    Hello!
    Yesterday, 03:27 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • kupa97
    Help recapping DFI motherboard
    by kupa97
    I have a DFI LANParty UT nF4 Ultra-D with A TON of bad capacitors and I need help deciding which caps to replace them with, I've never done this before so I'll use this as a learning experience. I have included a color-coded photo of every single bulging capacitor on this motherboard. All bad caps are KZG, the KY and KMG caps seem to be in perfect condition at least visually. I've read about replacing these caps with polymer ones, but I'm not sure which ones to buy. Thanks.
    BLUE = 470uF 16v 8mm x 11.5mm
    GREEN = 1000uF 6.3v 8mm x 11.5mm
    PINK = 1500uF 16v 10mm x 19.5mm...
    11-23-2025, 11:36 PM
