CapXon & Teapo 400v 100uf Caps
  • fcda
    • Nov 2009
    • 26
    • Scotland
    I've already posted about these in the Power Supply forum but not had any response (original thread).
    I'm trying to identify suitable replacements for a large 400v 100uf cap used in a Thomson DSI8215 Sky+ HD receiver.
    I've got a few power supply boards and the cap is either a Teapo or CapXon:
    - TEAPO 100uF 400v SH105°C 09/05 A3
    - CapXon 100uF 400v KM105°C C616 VENT
    Sizes: Diameter: 18mm, height: 32mm
    Can anyone help me find the specs and identify suitable replacements (preferably from RS)?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: CapXon & Teapo 400v 100uf Caps
    From RS UK I have chosen these caps:
    Panasonic 100uF 400V EETHC2G101BA
    Panasonic 100uF 400V EETED2G101BA
    They are 22mm diameter so I don't know if you have enough space for them.
    If they are not SNAP IN type then you can buy:
    Panasonic 100uF 400V ECA2GM101 this one is 18mm diameter but it is not 105ºC.
    If I were you I would buy one of these caps, Panasonic is a good brand.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • fcda
      • Nov 2009
      • 26
      • Scotland
      Thanks a lot Gianni.
      Can you tell me why you have chosen those ones? (not the brand but the specific capacitors).
      Obviously the capacitance and voltage are the same and the temperature is similar, but should I worry about ESR or ripple or anything else?
      • Gianni
        • Jul 2008
        • 681
        • Italy
        AFAIK ripple is not a big issue for input capacitors when they are filtering mains input voltage.
        If they are used as filter on APFC (active PFC) then they works more because they must filter high frequency current of the PFC converter.
        I have chosen them for the brand and current.
        The Teapo SH 18mm (dia) x 36mm, I found the datasheet right now, has a ripple current of 290mA, while Panasonic 100uF 400V ECA2GM101 has a ripple current of 600mA.
        The difference is Teapo is rated at 105ºC and Panasonic at 85ºC but both have life expectancy of 2000 hours.
        So I think you can use Panasonic because very often input caps are 85ºC rated.
        Check if you have enough space, Panasonic is 40mm long.
        Ciao
        Gianni
        H. J. Brown
          by momaka
          03-15-2023, 10:17 PM
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
