Mitre Saw start capacitor
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    Hi
    My miter saw like lots of things at the moment seems to have given up.
    I'm getting 240v to the switch, which I've tested for resistance when pressed giving about 0.08 ohms so i assume is OK
    The start capacitor has a rating of 0.47uf and I'm reading about 0.35uf, could this be the issue?
    The motor on the machine is a brushed type with two wires connected to it, should I be reading low resistance between these wires.
    Is there a way to test if the brushes are worn?
  • redwire
    • 3912
    Re: Mitre Saw start capacitor
    You should get continuity across the motor's terminals at the brushes.
    If you don't, try turn the shaft (by hand, it's unplugged) in case there is a dead spot.
    Sometimes a brush wears out, or they can get stuck from sawdust.
    If there's an open circuit I would take them out and inspect.
    • pintglass
      • Jul 2019
      • 79
      • United Kingdom
      I've just done a test by taking the armature out and connecting the brush terminals together and i get continuity, does this mean the brushes are not making contact.
      I'm not sure if this is a valid test, are the brushes there to complete the circuit, sorry if I'm completely wrong here.
        • Jul 2011
        • 6069
        Check the switch because sometimes one side of the switch only has continuity when the switch is pushed to ON
        But just because you get continuity that dose not mean that your switch is good
        and yes if brushes are not touching the armature commutator then the motor will not run
        sometimes the brush gets stuck in the brush holders
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • cind12
          GTX 1080 TI Gigabyte Aorus low resistance on vmem
          by cind12
          Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
          Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
          The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
          Resistance on 12V 4K ohms (Power present when on)
          Resistance on 12V PEX 4K ohms...
          12-08-2023, 09:09 AM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
