Car amp, headunit and crossovers
  • TheDragon
    • Feb 2011
    • 69
    • UK - 230 v
    Hi all, I would greatly appreciate some technical advice.
    I have acquired an old Pioneer car cassette HU - KEH-P8600R , which I plan to install (from around late 90's). It works fine, but my question is, due to its age, is it worth replacing the caps, even though its functioning fine?
    Secondly, I have a JBL amp, GTO75.4. Sonically, not the greatest but has served me well for more than a decade to run a sub and front component speakers. Again, it's working ok but is it worth replacing some caps. Would I gain anything?
    And thirdly, I have some component speakers, brought at same time as amp and used in two cars.
    These use passive crossovers. Would the caps in these be worth upgrading too?
    Thank you.
  • Retro-Hipster
    Tinkerer
    • Apr 2019
    • 125
    Re: Car amp, headunit and crossovers
    Hmm.. Do you have an ESR meter by chance? If it were me, I'd probably do an esr test on the electrolytic caps and, if they seemed ok, would put it back into service. (I'm a bit unprofessional though. lol) Past that, I probably wouldn't worry too much.
    Other than just testing the caps for a poor ESR and to see if they have the right capacitance, you could also use a spectrum analyzer (if you have one) and see if you have any distortion on the output. (using FFT) You could also just use an oscilloscope and do a basic sweep of the audible spectrum and see if you have any noise on the output. (If you don't have a signal generator then you could download sample tones/with pilot from the internet and play it from a music player.) This would let you know if you have any harmonic distortion or similar.
    One thing that may give us a better idea of if the caps need replaced is what brand the capacitors are. For instance, if they were a really cheap/well known for being bad brand we may recommend just replacing them because they are likely to fail anyways.
    “Men always seem to think about their
    past before they die, as though they were
    frantically searching for proof that they
    truly lived.”
    – Jet (Cowboy Bebop) -
    • TheDragon
      • Feb 2011
      • 69
      • UK - 230 v
      Hi Retro-Hipster, thanks fro chiming in.
      I don't have either, esr meter or oscilloscope unfortunately. Just a standard multimeter, that does read capacitance.
      Thats good advice, I will investigate the capacitor brands used.
      My guess is that the JBL amp will have middle to low quality caps,whilst the pioneer has some decent ones as they were top of the range units in their hay day. Then again I could be totally wrong.
      As the pioneer is 20+ years old, used in variable climate conditions,
      I wonder how much they deteriorate even if good brand caps?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        My guess is. If everything is working fine why go looking for trouble. I'll do any/all corrective maintenance when a problem arise.
        • Retro-Hipster
          Tinkerer
          • Apr 2019
          • 125
          Yeah, I'm kind of of that mentality too. If I have an attachment/really like something then I tend to do "checkups" before putting it back into service, but they tend to be pretty brief.
          Oh, this is barring old tech though.. If it's older tech I tend to give it a pretty good once over/don't plug it in until I've checked the power components and such.
          truly lived.”
          • TheDragon
            • Feb 2011
            • 69
            • UK - 230 v
            I generally agree to that too. It's just that, as I'm setting up a fresh, and the age of the equipment, I thought a good service would be useful after putting in the effort of installing.
            I looked into the pioneer unit, there are no bulging caps and most are panasonic m series, with 2 being elna branded. I couldn't say if they have deteriorated, but I'd say some would have, whether it effects the sound. I'm not an expert on that.
            Haven't had chance to disassemble the amp yet.
            • TheDragon
              • Feb 2011
              • 69
              • UK - 230 v
              Just learnt that the High pass filter on the amp isn't working. It's sending all the frequencies through. I'll have to check why.
                • 30919
                forget the caps if they arent leaking/bulged.
                but a warning - dont try to play any tapes without replacing the pinchroller(s) and any belts it may have.
                it will unspool your tape into the mechanism and be a right bastard to untangle.
                • TheDragon
                  • Feb 2011
                  • 69
                  • UK - 230 v
                  Well, all the caps seem ok.
                  Just tested all the frequencies coming through with test tones.
                  Apparently my MM can read frequency 0-20khz
                  Whether the character of the sound has changed, I suppose so, but thats subjective.
                  Just looking at an external crossover now.
                  Though Ive seen this too
                  https://www.ebay.co.uk/itm/NAKAMICHI...AAAOSwuytcSXgb
                  Of course, not the nakamichi of old, and cannot find any reviews.
                  STJ, I have indeed changed them. Always to point out.
                  It's electroluminescent display was dim, so I've replaced it and looks much brighter now. I did try to figure an LED alternative, but gave up.
                  A ribbon cable for the display is on order too, as the original is intermittent
                  I've acquired two more pioneers of the same decade (older), similar display/ribbon issues though. Will see whats more suited.
                    • 30919
                    ribbon?
                    so these are the ones where the front folds down to access the tape slot?
                    • TheDragon
                      • Feb 2011
                      • 69
                      • UK - 230 v
                      Yes, Stj. Apparently, it's a common repair.
                      My later model pioneer (got stolen), was motorised, used a different connection
                      • Bushcat
                        Pioneer PL-X9 motor speed control wobble
                        by Bushcat
                        I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                        Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                        BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                        05-24-2023, 03:36 AM
                      • pixelcap
                        Pioneer Kuro Pro 111FD 8 red blink error
                        by pixelcap
                        Pioneer Kuro Pro 111FD 8 blink red LED.
                        I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
                        So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
                        based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
                        10-06-2024, 11:26 PM
                      • RatherLoopy
                        Pioneer VSX-44 receiver HDMI dropouts
                        by RatherLoopy
                        I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                        I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                        And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                        05-26-2023, 03:54 PM
                      • Evets
                        Pioneer sg530
                        by Evets
                        This forum has been so useful to me and I thank all the people who have helped me in the past.
                        I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
                        07-30-2024, 07:18 AM
                      • Servicem4
                        Pioneer lx 701 hdmi issues
                        by Servicem4
                        My receiver pioneer LX 701 doesn't work anymore correctly The history:
                        6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
                        Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
                        The rest of the receiver works, I used spdif for sound input.
                        I now opened the receiver and hoped to find a blown fuse but all look good.
                        Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
                        Image 20250527-204839 hosted in ImgBB
                        05-27-2025, 01:13 PM
