REC capacitor
  • seemps
    • Mar 2009
    REC capacitor
    Hi friends;
    I want some info about REC(I don't know this is rec or pec) cap ,it's supplier and quality .
    thanks
  • Toasty
    • Jul 2007
    • 4171
    Re: REC capacitor
    It's Trec. Replace as they are know for problems.
    Supply us the diameter (in mm) and series number from the other side of cap. Trec uses a 2 LETTER code such as LZ, HR, GS, etc.
    http://www.trec-con.com/en-index.asp
    http://trec.myweb.hinet.net/
    Toast
    veritas odium parit
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
