A CHEAP source for ceramic caps?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Can someone recommend a good source for ordering a variety of ceramic caps? pF all the way to hundreds of uF in a pack would be ideal ... delivery times are not relevant, just looking for cheap.
    I'm seeing more and more often where specs are moving away from electrolytic caps, but most of the variety packs you get on Amazon only include ceramics with extremely small values ... I needed a couple of 10uF the other day and i only have ceramics in the small pF ranges ... very frustrating!
    sigpic
  • diif
    • Feb 2014
    • 6978
    • England
    Re: A CHEAP source for ceramic caps?
    I've got some capacitor sample books from Aliexpress. I had to add a few of the higher values (uF).
    • bestsystem
      • May 2011
      • 59
      taobao or ebay, i havent really encountered crap quality ceramics
        by momaka
        03-12-2025, 03:42 PM
        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
        by momaka
        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
        Macron Power Technology Co. LTD.
        Let’s look at the PSU itself.
        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
        06-02-2021, 10:05 PM
      • link626
        TCL 43s405 power board 81-PBE045-M02 (PLE100-2A) changed out the cheap caps
        by link626
        changed out the cheap HEC caps on my tv power board to a mix of nichicon chemicon and panasonic caps below.
        now there's louder buzzing noise from the yellow thing in the upper left corner. (anyone know what that yellow thing does? is that the transformer?)
        and the screen flickers in brightness. It's a light flicker, but noticeable.
        the buzzing ebbs and flows, like cicadas buzzing.
        in similar fashion, the brightness flickering ebbs and flows. the flicker might stop for a minute or two.
        these are all low esr caps, and I'm wondering if that might...
        08-08-2021, 11:11 AM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
