jamicon day creation
  • boombastik
    • Mar 2014
    • Greece
    Because i am new here i want to ask
    I have an jamicon cap 33uf 25volt sk.
    It has the code 526KO(m).
    This meaning that this capacitor created at 26 week of 2015?
    Thanks for your time
  • twonk9098
    Macbook Pro mid 2015 battery required to boot?
    by twonk9098
    I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
    The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
    This model has the newer trackpad which is not clickable when turned off.
    At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
    If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
    12-10-2024, 06:51 PM
  • ronaldo17
    Need schematic for my old laptop lenovo SuperX 5B CY420/CY510 NM-A711 rev: 1.0 2015 09 21
    by ronaldo17
    My board
    SuperX 5B VC
    CY420/CY510 NM-A711
    Rev: 1.0
    2015-09-21
    thank yoU if you can help me!
    07-21-2025, 09:09 AM
  • nicocorradini
    820-00426 (A1398 2015) no trackpad, no keyboard.
    by nicocorradini
    Hi! I have this 2015 A1398 with 820-00426 board that's driving me crazy. It originally came because of charging problems (MagSafe Board roasted, also MagSafe cable, etc. After disassembly, clean and assembly, my assistant (literally) broke FL803 and other componentes. Obviously, no screen or backlight. After replacing them, and also the LVDS connector, and LVDS flex on the screen, the board started fine, charges, chimes, shows Apple Logo, but surprise: no more trackpad or keyboard.
    Important notes:
    -Click works, so, trackpad is alive.
    -Already tried with another trackpad,...
    03-04-2025, 07:01 PM
  • ratoesan79
    Macbookpro 2015 not turn on after long sleep
    by ratoesan79
    Greeting..
    After a long sleep, my macbook pro 2015 a1502 won't turn on.
    When it is charged, it can be seen that the light is green then orange, but with SMC Reset and NVRAM both cannot also solve this problem.
    After I opened the bottom cover, I saw the fan spinning for a short time for about 1 second when the power button was pressed
    guess what I should check first,
    Oh I already have the scheme, it's just that I don't know where to start the inspection?​
    01-06-2025, 08:52 AM
  • yura8
    Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
    by yura8
    Hi there! I have not so usual situation...
    I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
    My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
    P.S. If you have else any ideas about repair, or you had a similar...
    12-20-2024, 02:31 PM
