Fake BB910 varactor diodes???
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    After a bit of internal debate I think these *are* capacitors despite also being diodes, so I post this here...
    I have a need for a varactor for a project. I was wondering about BB910s varactors. Apparently Philips has a datasheet with a DO-34 or axial version of this device, and I think Philips should be a reputable maker of semiconductors.
    However I'm seeing TO-92 crop-pin versions of this device from china marts. Anyone know if these are work-alikes or are they complete phonys and wouldn't even work like a varactor?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    Re: Fake BB910 varactor diodes???
    If you can get the genuine Philips ones from a proper supplier, then do that. You'll have much less of a headache that way.
    Forget generic Chinese parts except as a last resort. If they are actually varactors, they probably won't behave exactly the same as the genuine ones, and I doubt the Chinese are going to give you a datasheet which has the real specifications, if they are different. Even second-sourced parts from reputable manufacturers don't behave the same.
    If you use the generic ones and your project\repair\whatever doesn't work, you'll never know if the parts were fake or just the wrong number or if you did something wrong or what.
    Using genuine parts at least gives you a high degree of assurance (but not 100%!) that they will work as the datasheet says they will, and if they don't, then you know it was probably your mistake or something else in the circuit is faulty.
    Is the money you'll save on the generic parts worth your time and potential hassle for an unknown quantity?
    -David VanHorn
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Well this is for fun, and I really want to pay as little as possible for these things. It's not a repair job, and there's no real time schedule for them. I'm actually speccing possible parts for my project - just collecting possible parts that may or may not fit my needs based on their data sheets.
      But what I don't know is perhaps there is another manufacturer that does make equivalent working parts, really I don't care if it's DO-34 or TO-92; probably easier for TO-92 because I don't have to lead form when assembling it.
      Incidentally, Mouser has only ONE through hole varactor? Hmm... Working with through hole at the moment, so this will be a problem...
      I just found someone with a DIY kit that uses the TO-92 BB910 and does work like a varactor, else the kit wouldn't work... Might have to try it, mostly because I probably need to get two or more and hook up in parallel to get the capacitance I need.
      Oh jackpot! sort of...! I found an old dollar store "china" FM radio and found a varactor marked "B910" ... and since the radio at least worked at one point (haven't tried it yet...) the varactor should be working. So it seems that this part is somewhat rampant in duplication.
      Not sure if I can actually use the VCO in the TDA7088 directly yet however...would save me from making that circuit I need to replicate (but at a different frequency range...) If I short out the antenna input, the mixing DC with the VCO output would be... the VCO output, saving me from designing a VCO?
      • Agent24
        I see dead caps
        • Oct 2007
        • 5038
        • New Zealand
        Well, if you aren't fussed about the potential issues, the generic BB910s are probably OK. It just may make troubleshooting that bit harder.
        I don't know much about radio, but I doubt that shorting the antenna will achieve what you want. I'd guess you would need a completely different IC.
        -David VanHorn
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I probably need to get another one, the design I'm doing feasibility on is much slower than FM radio and probably needs more capacitance.
          I just thought of a better plan instead of mixing with a DC signal: mixing it with itself (if this is possible...) This should work plus increase amplitude! Except the fact there may be a phase shift, then that could be a problem, though possibly not insurmountable.
            • 31214
            probably the factory had a to92 molding machine but not a do34 one.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I think the TO-92 BB910s are not made by Philips, though no idea who. Definitely a clone of some sort, unfortunate that they used the same marking as Philips (annoying, these part number aren't controlled by JEDEC?).
              The DO34 case is probably more expensive, too, at least the Philips one is glass sealed I think when looking at the picture.
              • Dvsr
                On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                by Dvsr
                Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                After replacing the caps I started testing out the speaker. It seemed...
                09-10-2025, 10:20 AM
              • caspian
                What Zener Diodes on a Linear Power Supply
                by caspian
                Dear members,
                I have a linear variable power supply with unknown brand name that I used for voltage injection.
                Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                In addition, I discovered that its zener diodes are defective.
                I can replace the burned transistors.
                But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                Therefore, I cannot replace the zener diodes.
                I do not want to test the zener diodes in a test circuit to discover their model or value.
                no schematics are available...
                05-26-2025, 12:38 PM
              • Mark D
                Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                by Mark D
                The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                10-29-2024, 03:15 PM
              • Dannyx
                Panasonic TH-37PV7P (TNPA4268 PSU repair help)
                by Dannyx
                Good day folks. A colleague of mine scrapped his plasma TV after it quit on them, so I decided to dig it out and have a look inside myself to see if it's something that can be fixed relatively easy. I attached the schematic to save some time.
                The problem: shorted PFC transistor Q406 (page 65), shorted PFC diodes D417-420, open R448/R449, open R439/R493, open PR402, open R438, so yeah - quite a lot of damage. My colleague knows a little bit of electronics himself and tried replacing the FET himself but it blew again instantly, since he didn't know what else to check around it and...
                08-21-2021, 08:24 AM
              • tvtimmy
                More fake parts
                by tvtimmy
                I ordered 50 FGD4536 ibgt's from them and recieved 50 fucking blanks, useless Chinese forgeries for $44. I can get a full refund if I spend at least $15 to ship the garbage back to China for some other person to buy. I decided I would like to publicly disgrace them and just eat the $44. They advertised them as used but working. They came in a strip of new FAKES that looked nothing like the real ones. BEWARE OF THOSE SHADY BASTARDS!
                12-22-2021, 02:04 AM
