Replacement for CapXon LP
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    From a DLP power board. 200V 470uf, ripple is 2230mArms
    I can't seem to find anything close enough. Close enough decent quality I found was UCC EK, at 1770mArms
    diameter 25
  • Stefan Payne
    • 1267
    Re: Replacement for CapXon LP
    85°C caps allow higher current.
    look for those.
    if you can't find any ask manufacturer for advice.
    Because in some cases some 105°C caps can endure higher current but must be treated as a 85°C one in that case.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      might have found one
      https://cdn.badcaps-static.com/pdfs/...8344553467.pdf
      not sure about the leakage current though
      • Stefan Payne
        • 1267
        I've found something cheaper:
        https://www.mouser.de/ProductDetail/...mLf3dAMEETU%3d
        https://www.mouser.de/ProductDetail/...FpJyP7yEJtA%3d
        The others I've found don't seem to be available.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          zero available. and the ripple is at most 1970mArms. The one i'm replacing with is 2.2Arms
            master hoarder
            • May 2008
            • 12175
            CapXon's are fucking overrated. Just go with a quality Japanese brand and don't think of it no more.
            I had same problem when looking for some smaller Su'scon caps for an audio amp. Couldn't find a single reputable Japanese manufacturer that had a cap that met the specs of those Su'scons. So in the end, I just said, "f- this" and got some Rubycon YK and Nichicon VZ general purpose caps that were more or less close enough in specs to the Su'scons. After all, the Su'scons were GP caps too, so there's no way it could have mattered. And it didn't. The repair worked without a hitch and been working fine for a long time now.
              KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
              by momaka
              For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
              http://www.rmac.kingwin.com/products.../abt_650MM.asp
              I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
              What mostly drew me into buying it is its 2x PCI-E power connectors...
              03-29-2022, 11:34 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • the_rem
              Unknown transformer : how to find a good replacement part ?
              by the_rem
              Hello guys,
              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
              04-23-2025, 01:48 AM
              by momaka
              03-15-2023, 10:17 PM
