Video card Capacitor question
  • jayjr1105
    • 281
    In the image below, you obviously have the + and - leads. What is the other lead close to the negative? Is it a problem if that lead gets bridged with the negative when re-capping?
    https://imgur.com/i5y8AGo
    BTW, I assume crap caps?... http://prntscr.com/i1txzi
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Video card Capacitor question
    I have never seen a cap with 3 leads. If you post a pic of the underside of the board it would help in answering your question.
    • jayjr1105
      • 281
      I'm not saying the cap has 3 leads. I'm wondering what that pad close to the negative is for? It appears to be common on older video cards to have that pad super close to the negative lead.
      Ryzen 3600x
      FX-8802 Iron
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        It's to accommodate caps with different lead spacing, 5mm or 7.5mm in this case would be my guess.
        • jayjr1105
          • 281
          Are you guessing at the lead spacing differences or the accommodation part?
          Ryzen 3600x
          FX-8802 Iron
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Originally posted by per hansson
            it's to accommodate caps with different lead spacing, 5mm or 7.5mm in this case would be my guess.
            +10000
            • jayjr1105
              • 281
              I did confirm this with a continuity test. I guess if they bridge during a re-cap, it's no big deal.
              Ryzen 3600x
              FX-8802 Iron
