Are these caps bad?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Are these caps bad?
    If you want NO chance of silly problems the thing to do is replace:
    - Anything not on the 'good caps' list that has a vent. [No matter how small.]
    and
    - Anything not on the 'good caps' list that is 8mm diameter or bigger. [I do down to 6mm]
    and
    - Anything not on the 'good caps' list that is 470uF or more. [I do down to 220uF on critical boards.]
    Those are and's, not or's.
    Mann-Made Global Warming.
    - Dr Seuss
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
