Capacitor with little to no electrolyte in it
  • jazzie366
    • May 2016
    • 304
    So I got these two 16v 470uF "HDF" branded caps from a fake samsung charger. Well, I was bored so I opened the can to find little to no electrolyte in the cap. It was also as clear as water and had no smell.
    What's up with that?
    Popcorn.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Capacitor with little to no electrolyte in it
    Originally posted by jazzie366
    so i got these two 16v 470uf "hdf" branded caps from a fake samsung charger. Well, i was bored so i opened the can to find little to no electrolyte in the cap. It was also as clear as water and had no smell.
    wtf!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      How the f--k does that work?
      Also, there's no way that capacitor is 470uf unless somehow that clear stuff is some "special" electrolyte.
      I'm not a expert, I'm just doing my best.
      • jazzie366
        • May 2016
        • 304
        wtf!
        That's what I said!
        Popcorn.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
