Capacitor CS803 on BN44-00612B
  • moosets
    • Jun 2017
    • 7
    I have a BN44-00612B board with an obviously toast capacitor CS803 on it. Only problem is it fragmented the identification marks so I can't find a replacement part because I have no specs. I also cant find a datasheet anywhere. Anyone have any info on CS803 on the BN44-00612B?
    Thanks,
    Erik
  • R_J
    • Jun 2012
    • 9535
    Re: Capacitor CS803 on BN44-00612B
    I think its either 47pf or 22pf 1KV I see shopjimmy has a repair kit available which has several components in it.
    • moosets
      • Jun 2017
      • 7
      Ok I replaced it with a 47pf 1kv and it still doesn't work. It seems like the backlight flashes for a quarter of a second every few seconds still. Any ideas?
      • R_J
        • Jun 2012
        • 9535
        The ic or other parts near that cap could also be damaged, I dont have a schematic for that board, This one is for a BN44-00645a, The SQD2011k ic could be damaged and need replacing.
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
