A better understanding of ESR, power and temperature in a Capacitor
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    I have used a copy of Kemets caps explanation in the attachment of what to consider in calculating what parameters to consider when replacing capacitors or designing circuits with capacitor. It is a useful learning tool.
  • Drack
    Yup it's me
    • Nov 2016
    • 297
    • Venezuela
    Re: A better understanding of ESR, power and temperature in a Capacitor
    Thanks keeney, that's helpful.
    • MORETTIGIAN
      Capacitor detached from PCB – RTX 2070 Super Founders Edition
      by MORETTIGIAN
      Title:
      Description:
      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
      I did not notice it detaching, so I am unsure of its original location on the PCB.
      Procedure performed:
      - Removed backplate
      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
      - Reapplied thermal compound
      - Reassembled card
      Observed behavior after reassembly:
      - GPU powers on and operates normally under...
      09-18-2025, 12:14 PM
    • Prolog
      RTX 3080 FE Identifying capacitor
      by Prolog
      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
      I hope these photos make it clear which component I am referring to:
      (yes, the soldering is a bit botched from removing the blown one, I know)
      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
      12-01-2024, 08:27 PM
    • chth96
      If I replace with inferior capacitor, Is it No harm to other IC components at all?
      by chth96
      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
      I know that these capacitor will not last as long as nichicon capacitor...
      12-22-2023, 04:34 AM
    • chth96
      How can I test non-polarized capacitor?
      by chth96
      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
