Quadro FX 3000 - Identifying missing cap
  • sebz1337
    • Feb 2017
    • 4
    I've recently bought a used Quadro FX3000, and noticed that there was a missing SMD capacitor on the back of the card, as pictured below :
    Does anyone know the purpose / specs of this capacitor ?
    Thanks !
  • Behemot
    • 4845
    • CZ
    Re: Quadro FX 3000 - Identifying missing cap
    It's big so high capacitance. Plug it in and carefully measure voltage there, than select 6.3 V or 16 V depending on what you measure. X7R, highest capacitance you can find in that size.
    • R_J
      • 9624
      It's a ceramic cap. like others on the board, I guess you could measure one of the others, maybe .1 or 1uf
      Heres a picture
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        It's a "big" cap, maybe 10 or 22uF, try to desolder one of the others and measure.
        • Behemot
          • 4845
          • CZ
          It does not matter how much it is, just get the voltage and put the biggest one which fits. Filtering, the bigger the better. The card is at least a decade old, new ceramics greatly improved the volume capacity.
          • sebz1337
            • Feb 2017
            • 4
            Alright, I'll report back when I'll have the time to do some measurement!
            Will it be bad for the card to operate without this capacitor (short / long term side effects) ?
            • mariushm
              • May 2011
              • 3799
              Desolder one of the capacitors that look similar in size , like C535 for example, then measure the capacitance with a multimeter. (add solder to the ends and then as you heat up from both sides it will come off)
              If you measure it in circuit, the value may be wrong because sometimes the capacitors are in parallel.
              Once you get the capacitance you need to buy such a capacitor but with higher than normal voltage rating.
              If it's on the input, the AGP slot works with 1.5v and 3.3v so the voltage rating would have to be higher... but I suspect they're on the output of a buck (dc-dc converter) that converts the input voltage to some lower voltage (for powering memory chips or the chip itself), so basically the voltage would be less than 1.8v (if it's memory) or less than 1.2v (if it's gpu chip). The reason i suspect that is the presence of that diode D506 so close to the ceramic capacitors.
              So in theory you can use 4v rated or higher ceramic capacitors, but in practice ceramic capacitors drop significantly in capacitance as the voltage on them increases. So for example, a 10uF 10v ceramic may only have about 4-6 uF of capacitance with 5v on it.
              So even if the voltage is so low, you would have to pick some ceramic capacitor rated for at least 16-25v, otherwise the actual capacitance would be much lower.
              I think X7R capacitors of high capacitance and high voltage would be expensive.. I think even X5R would be reasonable here. It may be cheaper for you to buy 2 ceramic capacitors of lower capacitance and populate those two if they're in parallel.
              For example a 10uF 25v x7r may be 1$ but you could get 2 x 4.7uF 25v x7r for 0.2$ each.
                LENOVO 3000 J110 3000 J E6300 Specification for Upgrade or Repair
                This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...
                09-12-2024, 03:36 PM
              • plummmm
                Asus X570-P identifying potential missing SMD
                by plummmm
                I am trying to identify a potential missing component from an Asus X570-P motherboard. I could not find a boardview for that exact motherboard, but I did find one for the X570-Pro here https://www.badcaps.net/forum/troubl...prime-x570-pro
                The component missing on my board I believe is a small 3 pin device above the Nuvoton Super IO. The X570-Pro uses a similar Nuvoton and there's a similar looking SMD just...
                08-29-2025, 11:57 AM
              • Doyle1
                BMW OEM Amplifier 9 264 953 – Help Identifying Missing SMD Component
                by Doyle1
                I'm currently working on a BMW OEM amplifier, part number 9 264 953, taken from a 2011 BMW F10 535i.
                There's visible PCB damage near the NXP 74HCT193 chip, where a small SMD component is missing or burned. Based on shape and size, it's most likely a ceramic capacitor or resistor in 0603 package.
                I recovered the loose component (appears unmarked, like a ceramic cap) and have detailed photos:
                – PCB with missing part
                – Close-up of recovered component
                – Full view of the board
                I'm looking for:
                - The correct part...
                05-31-2025, 12:09 PM
                ACER Predator Orion 3000 600 I9200 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                This specification for the ACER Predator Orion 3000 600 I9200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 600 I9200 boardview and Predator Orion 3000 600 I9200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                09-12-2024, 03:28 PM
                ACER Predator Orion 3000 PO3-600 Predator Orion 3000 i5-8400 Specification for Upgrade or Repair
                This specification for the ACER Predator Orion 3000 PO3-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-600 boardview and Predator Orion 3000 PO3-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
