Thank You Bad Caps..!!!!!
  • mikesmith
    • Oct 2008
    • 8
    just wanted to say thank you SOOO much bad caps..
    and have it in the title..so everyone can see my thanks!
    read my other post here if you wana know why...
    THANK YOU BAD CAPS
    by momaka
    03-12-2025, 03:42 PM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
  • Foetuss
    Gigabyte GA-6OXT :: caps question
    by Foetuss
    Good evening
    I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
    Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
    But I was also suprised about the bigger boys, which are 330µF 25V.
    Could it be they used 25V caps because they were cheaper / available at that time?...
    02-11-2025, 12:22 PM
  • madscientist750
    Replacing electrolytic caps by solid caps on old motherboards
    by madscientist750
    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
    10-19-2025, 06:10 AM
