please help with videocard caps
  • Cartel
    • Feb 2006
    • 112
    I'm seeing residue around these 2 caps.
    I believe they are Lelon OCRZ.
    Would these even leak?
    (I didn't get a photo when I had the heatsink off)
  • Cartel
    • Feb 2006
    • 112
    Re: please help with videocard caps
    I'm being told by the manufacturer that these caps wont leak.
    Is that a fact?
    • jazzie366
      • May 2016
      • 304
      Is that a fact?
      Any cap can leak unless it's made with 1/4 inch thick aluminum and is solid aluminum, which doesn't exist.
      We'd need an actual photo to see if it's leakage or not.
      Popcorn.
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
