Chosing new caps
  • Darel-S
    • Sep 2016
    • 8
    • Slovenia
    Chosing new caps
    Hi everyone o/, Im trying to fix an old mobo lga 775 that have bulged caps on it and I have no idea which capacitors to buy. The original ones are OST 680uF 4V I think is this one --> soo what should I check on the new ones ? they must be low ESR or same voltage and capacity etc?
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Chosing new caps
    If they are on the CPU VCORE output, these should do fine (it should be safer to go one step lower in voltage if they are around the CPU):
    https://www.badcaps.net/store/produc...products_id=76
    The HNs linked below may be a better option if there's less margin in terms of voltage.
    • LEDSpex
      • Sep 2016
      • United States of America
      This old post is probably still relevant as to quality caps:
      https://www.badcaps.net/forum/showthread.php?t=414
      I am new to the forum but just discovered that this website has a store where you can buy the caps you need:
      https://www.badcaps.net/store/index.php
      The voltage rating can be higher than 4V, but the capacitance should be the same or as close as you can get. I think any caps you buy through this site will have reasonably low ESR characteristics.
      You also need to check the size of your caps to make sure the new ones will fit on your motherboard. Your data sheet shows the 470uF capacitor to be 8mm Diameter x 12mm Height and the badcaps 470uF 10V Nichicon caps are the same dimensions.
      https://www.badcaps.net/store/produc...roducts_id=207
      Hope this helps. If you are new to motherboard repair, you might not realize the board could have other damage, so this could be a learning experience. I tried replacing motherboard caps about 10 years ago and it was a fail. I don't mean to discourage you, just a heads-up!
      • Mint Waxed
        • Aug 2016
        • 35
        When selecting a replacement in addition to capacitance & voltage rating you should (using a metric ruler) measure the diameter, height, and lead spacing. Then if you go to Mouser Electronics and search "Electrolytic Capacitors, Leaded" you can read the parameters to make your selection. The Panasonic FR series are low ESR while the NHG series are Standard.
        • Darel-S
          • Sep 2016
          • 8
          • Slovenia
          Ty guys for all the replies I fixed it already, probably I didn't chose the best caps I could but its good enough 'mostly are panasonic fc xD' its an old mobo and its probably a waste of money to buy the best there is, its working for now and I'm happy with it. I learned a lot with it and I'm sure I'm gonna need some help in the future. ty again for your time
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
