Failing Elna RE2J and RJ4
  • Tux-Dave
    • Jun 2016
    • New Zealand
    An interesting day.
    I think we have finally found the cause of intermittent problems with the satellite TV boxes.
    From beginning of production 0818 (18th week of 2008) they were fitted with Elna RE2J capacitors. 220uf 25v. Having tracked the ethernet issue to 2 of these putting ripple on the 1.2 and 2.6v rails, I pulled all 15 caps off a couple of boards to test them. ESR ranged from 1.1 - 13 ohms for the RE2J caps, 2 Nipon Chemicon KZE 470uf were .01 ohms, 2 Elna 470 uf RJB were .05 ohms.
    Some time between 0918 and 0940 they started to use Nichicon VZ caps which measure between .23 and .4 ohms, the latter I think is a high ripple position on the 1.2v regulator cct.
    The beginning of 2011 they fitted Nipon Chemicon KMG, I haven't checked these out yet, but they are not known to be a troublesome date.
    That changed around 1140 when the fitted Elna RJ4's These tested from 1 ohm to over 100 ohms, or more than the meter can measure, 3 more of the 11 over 30 ohms. By 1218 they have moved to Taicon VT series which seem to be OK.
    This is what I can find on the caps
    Brand Series Ripple (ma) ESR
    Nipon Chemicon KMG 230 0.16
    Taicon VT 250 @120hz
    Elna RJ4 247 1.21
    Nichicon VZ 240
    Elna RE2J
    No Data on RE2j, Unlike most on Ebay (brown) These are blueish black. Brown made in Thailand, Black in Japan???
    Wow the RJ4 has high ESR, is that the cause of the failure do you think, maybe it was the same for the RE2J?
    I believe Elna has a good name so I suspect that they may have chosen the wrong caps.
    I think we will have to change these 11 caps in a couple of hundred thousand boxes
    on top of the power cable from PSU to main board, HDD Sata power cable, Tuner sockets.
    The never ending train wreck these things have been.
    The cap we are looking at using is the Nichicon PW series. Fairly cheap and better specs.
    BTW, apart from seeing a couple of caps with the tops swelled over the last 5 years, but not really bulged like the KZG Chemicons on the tuner sometimes do. These caps that I have tested all look perfectly OK. These are being used in digital circuits, around ram and flash chips so may not be what they were meant for.
    Any thoughts? Thanks
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Failing Elna RE2J and RJ4
    I've been using Nichicon PW and KL series in audio equipment for over 5 years and no failures yet. I did have one bad one out of thousands.
    sigpicThe Sky Is Falling
      1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
      I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
      This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
      12-29-2024, 07:18 AM
    • narf
      Epson EB-U42 projector / Caps with 0.7 ohms ?!
      by narf
      hi all,
      first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
      i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
      what i've found so far:
      - the PSU does its job and supplies 12V to the mainboard via the connector.
      - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
      - not far away, there's the first cap with a resistance of 0.7 ohms....
      07-02-2024, 03:53 PM
    • Ady2017
      Are there any datasheets available for Elna RJG capacitors?
      by Ady2017
      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
      05-25-2025, 02:19 PM
    • ResoluteHawk
      ASUS GA401QM Missing 5v
      by ResoluteHawk
      Hello;
      I have an ASUS G14 GA401QM that currently has no 5v rail among other things stated below in points #3 and #4. I'd like to see if it's condition can be improved.
      1) Originally this laptop had a problem with a shorted main power rail, so measuring at the current sense resistor after the DC IN FETs yielded a very low resistance. Before proceeding further I measured the CPU coils. We get 8.2 Ohms on the farthest right coil (PL8105) and 3.3 Ohms on the four to left left of it (PL8101 through PL8104). When I injected 1v into the current sense resistor, PQH9402 got warm....
      03-14-2023, 12:23 PM
    • gica69
      Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
      by gica69
      I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
      Resistor shows orange range silver gold and green lines.
      Thanks in adv...
      07-21-2025, 09:49 PM
